Keeping Thermostat Backlit Display On With No C Wire - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 06-08-2020, 09:51 PM   #1
Rewards Points: 54
Keeping thermostat backlit display on with no c wire
Hello to all,
I have a White-Rodgers -Emerson 1F95-1277 thermostat.
There is an option of keeping the backlight on continously if the system has a c-wire.
My system doesn't. I pulled a wire from the sytem transformer to the thermostat and the back light comes on only when the system is on.
My question is the following:
Can I connect a 24v tranformer direct to the thermostat to have the backlight on all the time?
If yes, I understand that I would connect one wire to the c terminal on the thermostat. where would I connect the other wire?
abekrausz is offline   Reply With Quote
Old 06-08-2020, 10:28 PM   #2
Rewards Points: 894
Re: Keeping thermostat backlit display on with no c wire
Originally Posted by abekrausz View Post
I pulled a wire from the system transformer to the thermostat and the back light comes on only when the system is on.
If I understand you correctly, you pulled a new wire from the transformer to the thermostat and connected it the C terminal. If so, you don't need an additional transformer. I think you need to go into the thermostat configuration mode and select the back light on continuous option.
57TinkerMan is online now   Reply With Quote
The Following User Says Thank You to 57TinkerMan For This Useful Post:
abekrausz (06-09-2020)
Old 06-09-2020, 08:27 AM   #3
Rewards Points: 54
Thanks a lot for responding.
Correct, I pulled a new wire from transfo to tstat. Problem is backlight only goes mon when system comes on for either heat or cool. As soon as system shuts off because of no call for heat or cool, backlight goes off. Do I need to connect my new wire somewhere else in the system then direct to the transfo?
Old 06-09-2020, 08:31 AM   #4
Rewards Points: 716
If you pulled a C wire it’ll be connected at the air handler and thermostat. After that the thermostat will be powered off the indoor units transformer.
What is the thermostat in question?
roughneck is online now   Reply With Quote
Old 06-09-2020, 08:33 AM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 162
You need to connect the C wire to the circuit board in the furnace and to the C terminal.
Then there should be a setting in the thermostat for battery operation ( choose NO ) and there may be one for constant backlight.
If you have it on battery operation it may not turn the light on all the time. The batteries are good for backup in a power failure.
Some new units have a temporary memory storage for several hours but keeping batteries in is a good idea IMO.
Old 06-09-2020, 08:49 AM   #6
Rewards Points: 894
If you have the C terminals (unit/thermostat) connected correctly as stated above, you need to configure your stat. Looks like screen reference #13 in the menu is your target.
https://www.manualslib.com/manual/10...?page=5#manual
Edit: You might as well go through the whole configuration menu and fine tune your system. If you have questions regarding this let us know.
Old 06-09-2020, 09:54 AM   #7
user_12345a's Avatar
Rewards Points: 38
except old batteries forgotten in have a tendency to leak - so op, make sure you still change them every few years.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 06-09-2020, 10:34 AM   #8
Rewards Points: 54
Thanks again,
I already went through the complete config menu and it did help me fine tune the system.
It's exactly menu # 13 that bothering me. If you look at page 6 of the manual, with a c wire, I should be able to keep backlight on all the time. As it is now, the backlight only hours on when system calls for either heat or a/c.
Old 06-09-2020, 08:51 PM   #9
Rewards Points: 616
Or better yet, REMOVE THE BATTERIES AND GET RID OF THEM. Sorry for yelling. I'm an HVAC guy and this is a pet peeve of mine. For most thermostats that are hooked up to a C wire, the batteries serve no real purpose. Most stats have either a permanent memory in them to remember the settings when the power goes out, or they have a hidden button battery inside for this purpose. If you have a C wire, you don't also need the AA's.
bfrabel is offline   Reply With Quote
Old 06-09-2020, 08:58 PM   #10
Rewards Points: 38
Honeywell uses a coin cell battery to keep the time.
The settings usually don't get lost on modern stats even when power is cut but for programmables, the time is lost.
So programmable units without the backup clock battery should have regular batteries left in even with a common connected.
Old 06-09-2020, 09:31 PM   #11
Rewards Points: 616
It's the Honeywells that I normally deal with, and like you said they usually will keep time even without the AA's in them, so that's why I don't put the batteries in.
Perhaps you're right and other makes will lose time if the power goes out and the AA's or AAA's aren't in there.
Thanks for correcting me.
Interestingly, on some of the Honeywell's, the coin battery is hidden and hard to get to and there's no mention of it in their owner's manual. Even some of the stat's that don't use a C wire (like some of the round T-87 versions) have this hidden battery in them. I believe these lithium batteries are supposed to last about 10 years, and then after that when it quits working Honeywell might be betting that you might be in the market for another new thermostat.
Old 06-09-2020, 09:34 PM   #12
Rewards Points: 38
don't know about other makes, have only dealt with honeywell.
The old ones like the magic stats, chronotherm 4s to my knowledge don't have the coin cell battery and lose the time.
The really old ones like the chronotherm IIIs actually lose the programming. (although otherwise they are fantastic and were really ahead of their time)
Old 06-09-2020, 10:03 PM   #13
Rewards Points: 54
Thanks to all for responding.
Issue not yet solved.
As mentioned, original older thermostat had only 3 wires and no c wire. Thermostat was recently replaced with the Honeywell F195-1277.
This tstat should have an option to keep the backlight on all the time with a C wire. I pulled a single wire from c terminal in air handler and connected it to c terminal in the thermostat. Now, the backlight comes on only when system is on. When system goes off, the backlight goes off as well.
I would really like to have the backlight on all the time. Any solution?
Old 06-09-2020, 10:27 PM   #14
Rewards Points: 894
Are the power stealing switches on the back of the stat on? You mentioned that you had only 3 wires in use before you pulled a common wire, is this a cooling only application?
Old 06-10-2020, 07:00 AM   #15
Hvac Pro
yuri's Avatar
Rewards Points: 162
Those power stealing switches are HORRIBLE and I NEVER use them.
They will bleed a small amount of power down thru W or Y to make a circuit and will damage most modern circuit boards. I had one make the AC contactor chatter like a machine gun and blew it.
I like White Rodgers but those power stealing thermostats should never use that function IMO.
User/buyer beware.
cheeno likes this.
