Jumper On Defrost. - HVAC - DIY Chatroom Home Improvement Forum
Old 02-26-2020, 09:00 PM   #1
Rewards Points: 300
What does this jumper do
as far as delay/normal on the Goodman/amana aph1560 heat pump defrost board .
What should I see it do on each jumper setting ?
Any info is appreciated
Jumper on defrost.-20180129_140946_1582772032217.jpg   Jumper on defrost.-20171103_142248_1582773976531.jpg   Jumper on defrost.-resized_20180130_141306_1582773999650.jpeg
hidden 1 is offline   Reply With Quote
Old 02-26-2020, 09:16 PM   #2
user_12345a's Avatar
Rewards Points: 88
Re: Jumper on defrost.
the board monitors the defrost thermostat and whenever it's at or below freezing, the thermostat is closed and the timer accumulates run-time.
The jumper setting determines how much run-time with the coil cold enough has to accumulate before it goes into defrost.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 02-27-2020, 03:47 AM   #3
An old Tradesmen
Rewards Points: 118
Should be a soft defrost jumper.
In delay, the compressor should stop running, then about 30 seconds later. The RV is energized and the compressor restarts shortly after that. Repeat for when it comes out of defrost.
Norm, would be the RV switching while the compressor runs like most other heat pumps do.
