Insulated Ductwork In Closed Crawlspace - HVAC - DIY Chatroom Home Improvement Forum
Old 05-12-2020, 04:52 PM   #1
Rewards Points: 34
Insulated ductwork in closed crawlspace
I plan to rerun insulated ductwork from the attic in a coastal mid-Atlantic area to the crawlspace which will be (further) sealed, insulated and conditioned. I will need a new trunk. Will this need to be insulated? In Green Acres fashion, what is wrong with just running the attic trunk right into the conditioned and sealed crawlspace and adjusting the floor registers accordingly.
Sent from my SM-N960U using Tapatalk
KurtP is offline   Reply With Quote
Old 05-12-2020, 06:17 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 848
Re: Insulated ductwork in closed crawlspace
If the crawl is sealed, it doesn't need to be insulated. Condition it. In the attic, needs to be insulated.
Old 05-15-2020, 06:55 PM   #3
Rewards Points: 34
A major advocate of sealed crawlspaces, and selling of supplies, suggested the ductwork there be insulated.
Old 05-15-2020, 07:16 PM   #4
Rewards Points: 848
Once the crawlspace is sealed, its basically conditioned space. I see no issue with making sure that the duct work is sealed for proper distribution, but to insulate it inside a space that should therefore be conditioned is wasted energy in my book.
Do you insulate the duct work in an unfinished basement?
