Installing A Nest E - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 05-22-2020, 03:12 PM   #31
Rewards Points: 894
Re: Installing a nest E
So, the B terminal in your air handler is common. You need to find/run a wire from there to the thermostat C terminal. Or find/run a wire from the condensing unit where the B wire connects and to the thermostat C terminal.
57TinkerMan is offline   Reply With Quote
Old 05-22-2020, 03:17 PM   #32
Rewards Points: 14
Yeah, I'm pretty sure this is the same brown wire, but I don't know what this black wire is that it is capped off with at the thermostat
Installing a nest E-img_20200522_131516_1590178596375.jpg   Installing a nest E-img_20200522_131535_1590178613430.jpg
Cesiumxrs286 is offline   Reply With Quote
Old 05-22-2020, 03:32 PM   #33
Rewards Points: 14
Originally Posted by diyorpay View Post
We need to agree what Brown and Black wires are that are twisted together at old thermostat. They are bypassing old thermostat and going elsewhere.
May be time for a meter reading to see which supplies 24V constant.
Suggest a pigtail from under cap (a third wire) same thickness if possible, to 'C' terminal on Nest.
Alternate method requires another transformer or bridge to supply 24V to Nest. We want to find it in existing wiring.
Yeah, I could use the cable the was the bridge on the y/w on the old thermostat, but would this effect whatever the black cable is doing?
Old 05-22-2020, 04:02 PM   #34
Rewards Points: 30
I feel that's the one you want as 'C'.
I would pigtail it because if it goes off with the black to somewhere else (likely the compressor that also needs a 24V constant) it's still what you need at the thermostat.
diyorpay is offline   Reply With Quote
Old 05-22-2020, 04:04 PM   #35
Rewards Points: 14
Going to try it out. Thanks for all your help!
Old 05-22-2020, 04:13 PM   #36
Rewards Points: 30
Let us know how it goes.
Old 05-22-2020, 05:23 PM   #37
Rewards Points: 894
Looks like you have a bunch of wires in the T-stat box. Maybe that's the junction you are looking for. Pull them out and see what you have, post pic.
Old 05-22-2020, 07:13 PM   #38
Rewards Points: 14
Alright!
It's on and it read the wires it seems like its working, BUT it feels like hot air when I press AC and cold air when I select heater???
Old 05-22-2020, 08:46 PM   #39
Rewards Points: 14
Fixed it. I just picked the wrong seating after heat pump. I picked B because that's what mines was but it's auto set to O. Switched it and we're good to go fam. No extra wires needed, no add a wire and no using the g wire. Got fully function heat, cold and fan! Thanks for all your help this was a fun DIY.
