Installing A Nest E - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 05-22-2020, 12:51 AM   #1
Rewards Points: 14
Installing a nest E
Help please,
I was planning on installing a nest thermostat. Watched a bunch of YouTube videos. Read different articles online. Checked the nest website and thought I had enough info to tackle this DIY on my own. Then I opened the HVAC system and the old thermostat. Now I'm super confused because the wires don't match. How can that be?
Installing a nest E-img_20200521_221104_1590126638821.jpg   Installing a nest E-img_20200521_223557_1590126654684.jpg
Cesiumxrs286 is offline   Reply With Quote
Old 05-22-2020, 04:31 AM   #2
An old Tradesmen
Rewards Points: 86
Re: Installing a nest E
Probably some of the wires go directly outside. Look for a junction in the thermostat wires. Trace them from the air handler toward the thermostat.
Old 05-22-2020, 05:50 AM   #3
Rewards Points: 724
Avoid the Nest thermostat. Lots of problems. Lots of issues. They are marketed as cutting edge, but they are nothing more then a novelty.
roughneck is offline   Reply With Quote
Old 05-22-2020, 10:07 AM   #4
Rewards Points: 14
All smart thermostats are novelty though. Just want to make sure I install it right the first time and not have to think about it after that.
Thanks for the junction box info. I guess it goes to the roof before coming to the thermostat. I wonder what my options are now
Old 05-22-2020, 10:16 AM   #5
Rewards Points: 724
Return the nest and look at WiFi options from Ecobee and Honeywell. Both are vastly superior and reliable compared to the nest.
Old 05-22-2020, 10:24 AM   #6
Rewards Points: 14
I get it. Nest isn't the best option out there. I've looked at the other choices. For my home it really just needs to be blowing cold air or hot.That's all I need. I get it there's even cheaper options then the nest to do that too, but here we are box is open and I just need some help.
Old 05-22-2020, 10:33 AM   #7
Rewards Points: 30
There are usually 2 'bundled' wire sets.
One goes to the compressor area. You say 'goes to the roof'. That's not the one you want to follow.
beenthere advised to trace wires from air handler to thermostat. That's the 'bundle' you want to see. Your second pic shows the colors at the thermostat as yellow (and it's jumped to 2 terminals), another yellow, orange, and blue or purple. That's the bundle you want to find somewhere in the air handler area.
Can't see from pic if you have a 'C' terminal at old stat. If you don't, this will be your challenge to get Nest hooked up correctly. Many threads in this forum about that.
First pic at air handler is hard to see if there's a 'C' terminal to tap off to bring to thermostat. If you don't have, it gets complicated.
diyorpay is offline   Reply With Quote
Old 05-22-2020, 10:53 AM   #8
Rewards Points: 14
Yeah that's where I was confused at the air handler it's 3 wires and at the thermostat it's 4... I've included a diagram
Old 05-22-2020, 12:19 PM   #9
user_12345a's Avatar
Rewards Points: 52
It's not a question of price, it's a question of the hardware and firmware being over-priced unreliable junk which causes problems.
Get rid of it and get a honeywell or even sensi if you don't want to spend a lot of money.
Based on the wiring it looks like you may have a heatpump and those are best left at a constant temperature in heating mode.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 05-22-2020, 12:28 PM   #10
Rewards Points: 14
I don't really follow your statement. You start of saying it's not about price, but end up talking about price.
We can talk about what is the best model for price ratio somewhere else. That's not why I joined. If you don't want to help that's also fine, but options on the best product isn't going to help me... Nest, Honeywell, sensi, or etc. I'm still going to need to figure out which wires go where period.
Thanks to those that are actually trying to help I really appreciate it! It's going to be 100 the next few days and I would like to try and have this ready for that.
Old 05-22-2020, 12:48 PM   #11
Rewards Points: 52
What I meant is not get something like a ecobee instead of nest because it's overkill for your needs, there are cheaper options than that which don't have major issues like the nest does.
Returning the nest should really be a given - to prevent future problems.
You already got good help on the wiring. The main thing you need is a common - this wire runs between the air handler and t-stat, connects to the C terminal if there is one, if not gets tied to the common side of the transformer.
Old 05-22-2020, 01:05 PM   #12
Rewards Points: 30
The yellow, brown and blue wires you're calling air handler: These leave (exit) the air handler and go to compressor in attic. These are not the blue, orange and 2 yellows from air handler board to thermostat. You have to find them somewhere else in air handler, possibly another board.
Look for some yellow wires coming from direction of thermostat.
Your blue wire on thermostat would normally be green and is for fan. It is probably connected to G terminal on board when you find it. Label your Blue wire at thermostat as 'G' or fan.
Your yellow wire (normally red) on thermostat terminal RH should be labeled 'R' or 'RH'. It is the 24V supply but for call only. It only supplies 24V when thermostat says 'I need power!' to heat or to cool.
Other yellow wire connected to both W and Y should be labeled as 'W' and 'Y' and needs jumping for both terminals. W is heat. Y is A/C. Your physical toggle switch on thermostat for 'heat' or 'cool' determines which. Off position does nothing.
Your missing wire for the Nest is 'C' common wire which is for constant 24V. Digital thermostats (usually with no batteries) especially with wi-fi control need this.
Orange wire may be heat pump related. Do you have a heat pump?
It is possible that the brown wire on your board that you have located is able to be tapped as a 'C' wire but has to be brought to thermostat.
Another suggestion: installers often use a wire bundle from air handler to thermostat but don't use all wires. Remove existing thermostat from wall to better see if there are spare wire(s) going to board that are not being used. One of those (if there) could be used as 'C' wire.
Old 05-22-2020, 01:30 PM   #13
Rewards Points: 14
Thanks for all those details. Yeah, I was on a chat with nest support last night and they said it was an air handler. I'm in a condo and that makes sense to me now because I'm guessing the compressor is on the roof somewhere. I don't see any other bundles coming from the air handler area. Is there a way I could tell there is an unused C-wire just by looking at it on the thermostat side?
Old 05-22-2020, 01:36 PM   #14
Rewards Points: 30
https://support.google.com/googlenes.../9452748?hl=en
Here's a pic of my air handler. Look for similar.
Old 05-22-2020, 01:48 PM   #15
Rewards Points: 14
The person I spoke to said it was an air handler. Here is a more zoomed out look and model number if that helps.
Installing a nest E-img_20200522_000344_1590173241427.jpg   Installing a nest E-img_20200521_233216_1590173259881.jpg
