Hypothetical Furnace Question - HVAC - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By user_12345a
  • 1 Post By beenthere
Old 02-01-2019, 01:55 PM   #1
craig11152's Avatar
Rewards Points: 1,210
hypothetical furnace question
As the title states this is hypothetical and I am curious what the answer is because I don't know.
suppose you had 2 houses identical in every way
Its cold outside....say -5F
One house sets the thermostat at a constant 67
The other at a constant 75.
Once both houses are at the desired temperature does the 75 degree furnace run more than the 68 degree furnace to maintain their desired temperature?
If so what is the physics behind it? Why does the 75 degree house lose heat faster?
I'm not a physics guy or an HVAC guy and I can't wrap my head around the logical answer.
Don't look at me. I didn't vote for either one of them.
craig11152 is online now   Reply With Quote
Old 02-01-2019, 02:05 PM   #2
Rewards Points: 1,106
Re: hypothetical furnace question
Assuming both houses have the same size and type of furnace, the one in the house set to the higher temp will run more to maintain.
Heat transfer is proportional to the temperature difference between inside and outside, all other things being equal. The role of the heating system is to replace the heat that's lost.
It's as if you have a bucket full of water with a hole at the bottom and you have to turn a tap on and off to maintain the correct water level. If you increase the water level, there's more pressure at the bottom of the bucket so it leaks faster and you have to have the tap on for longer periods of time to maintain the level.
craig11152 likes this.
WARNING: I am not in the business of any trade or topic I give advise on. Follow advice at your own risk. I have previous diy experience plus good knowledge of theory.
user_12345a is online now   Reply With Quote
Old 02-01-2019, 02:18 PM   #3
craig11152's Avatar
Originally Posted by user_12345a View Post
Heat transfer is proportional to the temperature difference between inside and outside, all other things being equal. .
That is what I was looking for. Does that have something to do with the 1st or 2nd law of thermodynamics?
Old 02-01-2019, 02:23 PM   #4
An old Tradesmen
Rewards Points: 7,440
Heat transfer is linear. For every 1 degree of temp difference X BTU of heat is lost or gained.
In your scenario, at -5F, if the 68F house requires 60,000 BTUs of heat to keep it at 68, then its losing a rounded 857 BTUs an hour per 1 degree of temp difference between the outside and inside.
The 75F house is losing 962 BTUs an hour per degree of temp difference between indoor and outdoor temp.
So the 75 degree home's furnace runs more often, and longer. And at -5F outdoor temp would need 66,856 BTUs an hour.
Old 02-01-2019, 02:26 PM   #5
Temperature is the intensity of heat.
Heat is molecules of a substance moving around/vibrating and the higher the temperature, the more they move around/vibrate. You get more conductive and radiant heat transfer with more movement/vibration.
For convection, the hotter the fluid is, the lower the density, so the greater the temp differences is between fluids, the more the hot fluid gets displaced by cold fluid.
In a house you have cold, dense air leaking into low areas and hot air leaking out of high areas, ie attic ceiling. Initially, it starts with cold air displacing and pushing the warm air up, but once this process gets going you get a stack effect with warm air rising up, leaking out and cold air being pulled in. (technically, there's no suction -> just area of low pressure caused by warm air rising up and cold air of higher pressure from outside rushes in to replace it and equalize pressure)
High density energy moves to area of lower density?
third law -> https://en.wikipedia.org/wiki/Third_...thermodynamics
Old 02-01-2019, 02:29 PM   #6
craig11152's Avatar
I assumed the 75 would run longer I just had no clue why. I appreciate the time you guys took to pass on your knowledge.
Old 02-01-2019, 02:34 PM   #7
Rewards Points: 6,706
No its just heat transfer science.
There are three modes of heat transfer--- conduction, convection, and radiation. What has been discussed on this thread is conduction heat transfer. There will also be some effects by convection and radiation. Its actually a very complex science, but to say that if the temperature difference between inside and outside goes up by 10%, the energy lost will go up by 10%, is a reasonable approximation. Unless you are NASA.
SPS-1 is online now   Reply With Quote
Fedders Furnace Fan Question capt1857 HVAC 6 05-23-2016 11:02 AM
New Furnace & Plenum Install Question rb404 HVAC 3 03-03-2012 11:29 AM
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 08:31 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
Electric Furnace question whatsthis HVAC 32 04-08-2009 07:39 AM
