HVAC ... Duct Work, Vent Cracks Sealing Method - HVAC - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By user_12345a
  • 2 Post By beenthere
Old 09-15-2020, 09:41 PM   #1
Rewards Points: 68
HVAC ... duct work, vent cracks sealing method
For sealing cracks between vents in HVAC i always see a bright silver color tape that's used by professionals.
I bought this at HD today.... since it was in HVAC section and only $4... lol.
Can this be used to seal cracks to prevent a.c.... or heat to leak from return vents.... usually where one joins with another or near screwed in sections...
I feel the a.c. leaks where we attached a humidifier for use in winter. .. this in return duct section.
Please advice, should i return this and get a better one?
Thx
miserkris1 is offline   Reply With Quote
Old 09-16-2020, 01:35 AM   #2
user_12345a's Avatar
Rewards Points: 42
Re: HVAC ... duct work, vent cracks sealing method
Fabric duct tape consistently fails when used on air ducts. You'll be re-doing it - it will fail anywhere from few months to couple of years after application.
Use the foil tape instead. It can last decades.
Windows on Wash likes this.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
The Following User Says Thank You to user_12345a For This Useful Post:
miserkris1 (09-16-2020)
Old 09-16-2020, 05:34 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 842
+1. This is NOT one of the 1,000,000 applicable uses of ductape.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 09-16-2020, 05:37 AM   #4
An old Tradesmen
Rewards Points: 54
Cloth duct tape is good for many uses. Just not on actual duct though.
Return it.
You want foil faced, UL181 listed tape.
bob22 and Windows on Wash like this.
The Following User Says Thank You to beenthere For This Useful Post:
