HVAC Duct In Garage Condensation - HVAC - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 1 Post By Nealtw
  • 1 Post By ryansdiydad
  • 1 Post By Yodaman
  • 1 Post By ss427
Old 03-09-2019, 09:07 AM   #1
Rewards Points: 12
HVAC Duct in Garage Condensation
Hello, This HVAC duct is surface mounted against the ceiling in my garage. If I need to have the outside doors open for any length of time during the summer months a lot of condensation forms on the duct. I am thinking of gluing rigid foam insulation material as pictured directly to the duct to encase the duct to seal it off from the garage air. I have read where the foam panels are not meant to be left exposed but the "firewall" is still the ceiling material which is undisturbed. Is there some better way correcting the problem? Thank you.
HVAC Duct in Garage Condensation-img_4135.jpg   HVAC Duct in Garage Condensation-img_4132.jpg
ss427 is offline   Reply With Quote
Old 03-09-2019, 09:12 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,288
Re: HVAC Duct in Garage Condensation
Is there a height issue there? Otherwise, I would prefer to see it covered in foam and drywall.
Be sure to seal all the seams as it should have ZERO communication with what is in the garage.
The Following User Says Thank You to Windows on Wash For This Useful Post:
ss427 (03-09-2019)
Old 03-09-2019, 09:29 AM   #3
Rewards Points: 12
Well it is pretty low in there, about 78 inches between the floor and the bottom of the duct. It is toward the corner where you normally don't walk though.
Old 03-09-2019, 09:33 AM   #4
retired framer
Rewards Points: 13,860
Google fire safe duct insulation.
Foam need to be covered with drywall and that should have been boxed insulated and drywalled but there are products you can use there. It should be fire rated to slow a garage fire from getting to the house.
Windows on Wash likes this.
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
The Following User Says Thank You to Nealtw For This Useful Post:
ss427 (03-09-2019)
Old 03-09-2019, 09:42 AM   #5
Rewards Points: 12
OK, I am convinced. I'll box it in. What would you use as the insulation material? Is regular 1/2 drywall ok for the enclosure or does it need to be something else?
Old 03-09-2019, 10:58 AM   #6
Rewards Points: 990
There's duct insulation that can be used if you don't want a major foam/drywall job.
may be hard to install though:
WARNING: I am not in the business of any trade or topic I give advise on. Follow the advice I post at your own risk. I only have previous diy experience plus good knowledge of theory.
user_12345a is online now   Reply With Quote
The Following User Says Thank You to user_12345a For This Useful Post:
ss427 (03-09-2019)
Old 03-09-2019, 11:36 AM   #7
You need to insulate it in conjunction with boxing it in.
If you detail out the seams and seal the ductwork, 1/2-1" will probably be sufficient.
ss427 (03-09-2019)
Old 03-09-2019, 11:48 AM   #8
retired framer
If you are boxing it you foam will be fine just seal that to the ceiling and the build the two sides just low enough the the bottom drywall clears the insulation. 1/2" drywall is fine. For less than 2 feet you don't need the 2x4s on the bottom but finding a joist running in the same direction can get tricky.
ss427 (03-09-2019)
Old 03-09-2019, 11:58 AM   #9
Rewards Points: 1,502
Thermax foam board can be left exposed. But boxing it in just looks better.
https://www.dupont.com/products/THER...nsulation.html
Nealtw likes this.
ryansdiydad is offline   Reply With Quote
The Following User Says Thank You to ryansdiydad For This Useful Post:
ss427 (03-09-2019)
Old 03-09-2019, 12:22 PM   #10
retired framer
It looks like we can see some dirt on the wall below the right hand corner, that is bad news anyway. You can not allow an air leak from the garage in to the house.
Auto off gasses are a killer.
ss427 (03-09-2019)
Old 03-09-2019, 12:27 PM   #11
Property Mgt/Maint
Rewards Points: 6,226
A few years ago, I was looking for a fire rated foam board. No one stocked it locally. I finally got a quote from 84 lumber, it was 2 times the coast of regular and I had to buy in bundle quantities. It really wasn't practical for my application.
Side note: there was some question earlier about there already being a fire wall in place implying that maybe the foam didn't need to be covered.
The covering of the foam is to prevent the rapid toxic off gassing in case of a fire, and has nothing to do with the fire rated wall.
Nealtw likes this.
[political signature removed]
Yodaman is offline   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
ss427 (03-09-2019)
Old 03-09-2019, 02:07 PM   #12
Originally Posted by Yodaman View Post
A few years ago, I was looking for a fire rated foam board. No one stocked it locally. I finally got a quote from 84 lumber, it was 2 times the coast of regular and I had to buy in bundle quantities. It really wasn't practical for my application..
Yeah. I was gong to mention that but got lazy. The big box guys won't even know what it is and when you track down someone that does they will tell you that you have to order a truckload. Do not bother with either.
You might be lucky if you have a good local lumber yard. My local lumber yard knew exactly what it was and said they can get any quantity with no minimum. Haven't ordered any yet to see if it's true.
Yodaman likes this.
ss427 (03-09-2019)
Old 03-09-2019, 05:52 PM   #13
Rewards Points: 12
You folks are awesome. Thank you for the helpful replys.
Nealtw likes this.
garage roof condensation excessive Martina10 Building & Construction 17 03-06-2015 09:58 AM
Replacing Duct Tape Used on HVAC Ducts yarrick19 HVAC 5 06-17-2012 11:29 PM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 09:21 AM
Properly Sealing HVAC Duct Work craymer45 HVAC 5 11-06-2008 08:47 PM
