Humidity Control On Thermostat Not Working - HVAC - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 08-31-2020, 08:42 AM   #1
Rewards Points: 16
Humidity control on thermostat not working
Hi folks,
The thermostat (Trane XL824) allows you to enter a target humidity level. Unfortunately, it's not getting there.
Right now (early morning here in NC), here's the info from the thermostat:
"Cooling target" = 55%
"Indoor Humidity" = 65%
"Cool to 74F"
"System Idle at 73F"
Outdoor Temp = 71F
Outdoor Humidity = 90%
Is it because the set point of 74F is too high? The problem with lowering the setpoint this past summer is that is got seriously freezing inside. We've had to go outside to warm up
There are no obvious air leaks from the outside to inside the house.
This is a fairly new HVAC system (put in 3 years ago)
I contacted Trane online more than a month ago (twice) but no response.
The obvious solution would be to get the HVAC technician to come on over but with this virus raging that maybe not a good idea right now.
Cheers
Epictetus is offline   Reply With Quote
Old 08-31-2020, 09:10 AM   #2
Rewards Points: 318
Re: Humidity control on thermostat not working
Raise the set point to 77 and see if the humidity goes down.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Epictetus (08-31-2020)
Old 08-31-2020, 11:17 AM   #3
Rewards Points: 1,542
Sounds like it's set up with "overcooling" enabled for dehumidifying. basically it'll keep running to pull the humidity out, even if you reached the set point. this can work, but it's not the best method. if it's cooler outside than inside, there likely isn't enough thermal load in your house to allow the coil to get cold, get saturated, and start draining out water by the time it cools down the house.
many of those thermostats have the option to control a whole house dehumidifier. if where you are in NC is very humid even when it's not hot out most of the time, this is the direction I would steer you.
u3b3rg33k is offline   Reply With Quote
The Following User Says Thank You to u3b3rg33k For This Useful Post:
Old 08-31-2020, 12:34 PM   #4
Rewards Points: 16
Thanks for the replies!
Wow. That's interesting. Not sure where you are coming from but I'll give it a try! Is this just a test?
Originally Posted by u3b3rg33k View Post
...it'll keep running to pull the humidity out, even if you reached the set point....
OK, I'll contact the HVAC company because the humidity set point is obviously not over-riding the temp set point, as it should.
Never even thought about a dehumidfier!
Many thanks!
Old 08-31-2020, 01:30 PM   #5
Rewards Points: 16
I must be losing it.
My wife just pointed out that we tried a dehumidifier a couple of years back. It pumped out such an incredible amount of heat as to be not an option.
Works great in the crawl space though.
Old 08-31-2020, 01:39 PM   #6
user_12345a's Avatar
Rewards Points: 58
Your t-stat either over-cools a couple of degrees below the temp setpoint to reach humidity setpoint, slows the blower down to improve dehumidification, or both.
This is assuming it was set up properly.
Your unit can not dehumidify without cooling. When it's mild, even with overcooling enabled, it won't run long enough to dehumidify to 50% on it's own. Only a dehumidifier can do that.
Run exhaust fans when cooking and showering - that helps.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
The Following User Says Thank You to user_12345a For This Useful Post:
Epictetus (09-01-2020)
Old 08-31-2020, 02:51 PM   #7
Rewards Points: 318
Not a test, just a fact.and this 8 % reduction in R H is without any moisture removal.
http://dpcalc.org/
Edit: Edit:
Old 08-31-2020, 05:35 PM   #8
An old Tradesmen
Rewards Points: 86
http://dpcalc.org/
Edit: Edit:
Of course, thats presuming that there also is no moisture gain from the longer off cycle.
The Following User Says Thank You to beenthere For This Useful Post:
Old 08-31-2020, 05:51 PM   #9
Rewards Points: 318
That should be perfect being everyone here seems to want a longer run cycle and moisture needs to be removed before the temperature will make a significant change.
Old 08-31-2020, 06:01 PM   #10
An old Tradesmen
Rewards Points: 86
But raising the thermostat set temp, shortens run time.
Old 08-31-2020, 06:05 PM   #11
Rewards Points: 318
Not if there is moisture increase. Moisture has to be removed to reduce temperature equals more run time.
Epictetus (09-04-2020)
Old 08-31-2020, 07:19 PM   #12
An old Tradesmen
Rewards Points: 86
Actually, moisture doesn't have to be removed to lower temp.
Many systems only remove a small amount of moisture, leaving the home with a high RH. Specially as outdoor temp decreases.
Old 09-01-2020, 01:15 PM   #13
Rewards Points: 16
OK, folks.
Many thanks for the replies.
Lots to think about.
Maybe, because we are getting to be a bit elderly, my wife and I are more susceptible to slightly colder conditions. For example, right now, at 1pm:
From thermostat readout:
System is idle
Setpoint 71F
Humidity 66%
Humidity Setpoint 60%
Outside Temp 75F
Outside Humidity 90%
In one room with an Accurite thermometer:
68F
64%
For us, it's unpleasantly cold in this room, especially when the AC starts to kick in.
Is using a small ceramic heater too stupid.
Cheers
Old 09-01-2020, 02:09 PM   #14
Rewards Points: 904
Take your dehumidifier out of the crawl space and run the hell out it. Removes moisture, adds heat and you get longer run cycles from the a/c.
57TinkerMan is offline   Reply With Quote
The Following User Says Thank You to 57TinkerMan For This Useful Post:
Old 09-01-2020, 02:29 PM   #15
Rewards Points: 58
i don't think it's set up properly.
