How To Vent 8" Duct In Basement? - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By DIY_1
Old 12-28-2017, 10:07 AM   #1
Rewards Points: 6
How to vent 8" duct in basement?
I am in the process of installing a 200 CFM ERV system in the basement and am trying to place the Exhaust and Fresh air vents to the outside.
The issue is the siding goes almost all the way to the ground and the joists are 2x10's, so whatever vent I place will not give me enough ground clearance to the outside. Even if I use a 3 1/4" x 14" rectangular vent and place it just under the subfloor I will still only have about 7" of ground clearance.
What is the recommended way to handle this?
DIY_1 is offline   Reply With Quote
Old 12-28-2017, 10:20 AM   #2
retired framer
Rewards Points: 20,276
Re: How to vent 8" duct in basement?
perhaps a snorkel
https://texags.com/forums/61/topics/2820966
Nealtw is offline   Reply With Quote
The Following User Says Thank You to Nealtw For This Useful Post:
DIY_1 (12-29-2017)
Old 12-28-2017, 11:12 AM   #3
Rewards Points: 6
Thank you for the suggestion. I have found this in my google searches as well for use with fireplaces. Do you know of where I could purchase one to use for fresh air and exhaust for an ERV system?
Old 12-28-2017, 12:45 PM   #4
retired framer
That one looked more like a special order from a sheet metal shop.
You can't get up in a closet then out??
DIY_1 (12-29-2017)
Old 12-29-2017, 10:16 AM   #5
Rewards Points: 6
Unfortunately, the only closet attached to an outdoor wall is a 30ft run from my furnace in a crawl space and wouldn't allow for me to put both exhaust and intake in there.
I have a sheet metal shop making me a custom unit like the one you sent me.
Thanks for the advice.
Nealtw likes this.
Tags
clearance , erv , grade , ground , vent
AC air temp much warmer at one vent (room) than all others. tearitup HVAC 54 07-25-2015 03:23 AM
New Duct supply runs for basement finishing project svaic00 HVAC 6 07-10-2013 04:58 PM
moving duct for vent in wall question jhack836 HVAC 0 08-05-2012 10:39 AM
Vent questions for basement barsink danielrg Plumbing 7 08-28-2011 02:33 PM
Enclosing access to duct "valves" in basement. Chucky Jesus HVAC 4 08-21-2009 03:32 PM
