How To Seal Gap Between Filter Box And Air Handler - From The Inside - HVAC - DIY Chatroom Home Improvement Forum
Old 05-26-2020, 12:26 AM   #1
Rewards Points: 24
How to seal gap between filter box and air handler - from the inside
I have moderate sized gaps between my filter box and air handler. I plan on using foil tape to seal these, except for the rear seam. Because the furnace sits close to the wall/soundproofing, I cannot access this gap from the outside. I worry about using foil tape to seal the gap from the inside (will I run the risk of the tape coming off and getting sucked into the blower?)
How would you seal this area?
How to seal gap between filter box and air handler - from the inside-filter-box.jpg
Pajamas is offline   Reply With Quote
