How To Replace Honeywell 8 Wire Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By user_12345a
  • 1 Post By 57TinkerMan
Old 08-28-2020, 07:28 PM   #1
Rewards Points: 4
How to replace Honeywell 8 wire thermostat
Hi Everyone, I am trying to replace one old 8 wire thermostat in my condo. But my new thermostat has only 5 wires, I don't know to do it, are there anyone who could help me out?
Old model is Honeywell T8575D2003
New model is Honeywell RTH2300B
Thank you very much.
How to replace Honeywell 8 wire thermostat-old-2.jpg   How to replace Honeywell 8 wire thermostat-old.jpg   How to replace Honeywell 8 wire thermostat-new-1.jpg   How to replace Honeywell 8 wire thermostat-new-2.jpg
Heavyduty123 is offline   Reply With Quote
Old 08-28-2020, 08:03 PM   #2
user_12345a's Avatar
Rewards Points: 108
Re: How to replace Honeywell 8 wire thermostat
Wrong stat, need one that will work with your fan-coil.
Mechanical may be the condo corporation's responsibility and best not to mess with it if that's the case.
Heavyduty123 likes this.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 08-28-2020, 08:12 PM   #3
Rewards Points: 918
The new thermostat is not correct for your application. Would need to know more about your system, 2 pipe, 4 pipe, zone valves etc.. Could probably make the new one work but you would probably have to settle for one fan speed. Attached is wiring info for the old thermostat if anyone wants to take a stab at it.
https://customer.honeywell.com/resou.../95C-10897.pdf
57TinkerMan is online now   Reply With Quote
Old 08-31-2020, 04:04 PM   #4
Rewards Points: 4
Thanks for your reply. I did some reasearch in the internet, then I decide to buy a new 'Honeywell SuitePro TB8575a1000 24V Thermostats' which seems a compatible replacement.
They sais the#6 wire in old device for fan com will be unconnected, I hope it works.
Tags
5wire , 8 wire , honeywell , replace , thermostat
