How To Properly Install A Condensate Line. - HVAC - DIY Chatroom Home Improvement Forum
Old 10-22-2015, 01:43 PM   #1
Rewards Points: 87
How to properly install a condensate line.
I just had the head of a ductless mini-split unit switched from a condensate pump over to a through the wall run to a nearby washer/dryer stack and I am not really pleased with the work.
This is probably my favorite part. I really like how they notched the studs of my load bearing wall instead of drilling it after I took the time to sister on that plywood with structural screws like my engineer suggested....
This shouldn't be any trouble to finish over right? Drywall is super flexible. Just smoosh it all together.
And sure lets just jam that down in there with washer drain pipe. Why not.
I don't really want to call them back to "fix" it again. I would rather just do it correctly myself.
I can fix the wall studs myself but am not sure of the best way to fix the drain.
What is the best way to connect that condensate line to my washer/dryer stack?
I was thinking of using the right side punch out of the washer outlet box and running that down to tie into the washer drain line to share the existing p-trap.
My contact with the company who scheduled this was talking about some kind of specific trap to use with this sort of setup, although clearly they didn't bring or use it. Is this a condensate trap? Or something special for ductless mini splits?
hellonoko is offline   Reply With Quote
Old 10-22-2015, 05:11 PM   #2
Rewards Points: 2,005
Whats with the loop in the drain hose ? Is that their idea of a trap ?
The washer drain has a trap at the bottom , where it heads to the right .
Is this pier and beam or concrete slab ?
God bless
Wyr
WyrTwister is offline   Reply With Quote
Old 10-22-2015, 05:27 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,576
First of all mini-spilts do not drain a lot of water and are notorious for that water sitting in places and building up algae when it becomes stagnant and then plugging the pipe. I would rip that flex crap out and use smooth 3/4" pex or cheap black poly pipe as it is flexible and then connect it somehow above the trap in the pipe the washer uses. You can get angle Y fittings to hookup washers and possibly hook it into there.
Old 10-22-2015, 05:31 PM   #4
Rightly or wrongly , on our 2 MS's , I used 5/8" automotive heater hose left over from another project . This fit the factory corrugated drain tube .
Both drain to the outside ( through the wall ) , on the ground .
God bless
Wyr
Old 10-22-2015, 05:35 PM   #5
Hvac Pro
yuri's Avatar
I would take the tube they supplied and make it short and adapt it to some 3/4" pipe. The smoother and least amount of kinks the better.
Old 10-22-2015, 05:36 PM   #6
CompleteW&D's Avatar
Rewards Points: 524
God bless
Wyr
When I first saw that, I thought the same thing. Either that, or they were just too lazy to cut the excess.
Plus, I've never seen any condensate drain line that's "corrugated" like that. Condensate drains are generally clear, flexible PVC. That drain has potential to trap moisture all along it, causing mold and mildew build up over time. A couple of years from now, you will likely start smelling it.
If it were me, I would demand they come and re-do everything. And, tell them this time, have their right angle drill with them to properly drill those studs.
As far as sistering in the drain with the washer drain, I have no problem with that. I would zip tie them together though, just to make sure the condensate drain line (the clear PVC one) doesn't pop out.
CompleteW&D is offline   Reply With Quote
Old 10-22-2015, 05:40 PM   #7
Rewards Points: 19,124
Why is it not just draining to the outside?
Should have been drilled holes in the studs not notched.
A water wall should have been 2 X 6 not 2 X 4's.
Even that dryer vent hose should be trashed.
It would burn through in about 30 seconds.
Looks like that washer box was installed up side down.
Old 10-22-2015, 05:42 PM   #8
Post should read, "how not to install a condensate drain"
Old 10-22-2015, 06:21 PM   #9
Rewards Points: 87
@WyrTwister - Yes, I think that is their idea of a trap, or a high drain loop? Not sure really. This is concrete slab but this is on the 2nd floor so not on the slab.
@yuri - Thanks. I will check that out. I have a an expansion pex tool so I could do that easily.
@CompleteW&D - Thanks for the notes. I also think they should fix it but then I'm sort of thinking.. what else will they break while 'fixing' it? Might just be easier to fix myself.
@joecaption - It's not draining to the outside because it's on an interior wall. Yes they should have drilled, thus this post... What should the dryer vent be replaced with?
Old 10-23-2015, 06:08 PM   #10
Rewards Points: 80
Most ductless unit's have the condensate on the high side, so no trap required. Double check your manual though. I too would have used 3/4 pvc. It helps prevent blockages.
I probably would have "y'ed" off the drain instead of jamming it in like that, but it works.
The stud work is great...... Erm yeah...
Cheers!
supers05 is offline   Reply With Quote
Old 10-23-2015, 06:24 PM   #11
Plumber
TheEplumber's Avatar
Rewards Points: 402
Make the suggested smooth wall pipe repairs as suggested, for the for the washer box- cut in a 2" inverted wye in the stand- up pretty high- point it toward the right side of the box. On the branch of wye use a 45 to align to the knock out hole at the right side of the box. Of course, add pipe between the fittings. Use ABS glue at the joints
Feed your condensate tube through the top hole and into the removed knock out on the right. Done deal
The Following User Says Thank You to TheEplumber For This Useful Post:
CompleteW&D (10-24-2015)
Tags
condensate , drain , minisplit , plumbing
location of condensate drain line nugentcn HVAC 7 06-28-2015 04:50 PM
AC Condensate line ssgtjoenunez Plumbing 18 03-12-2013 07:08 PM
Condensate pump install question kboorman HVAC 6 07-06-2012 07:54 PM
Condensate line clogged? kcrossley2 HVAC 6 07-27-2011 10:51 AM
Gas Dryer - Install Flex Line and Also No Heat mark2741 Appliances 8 07-05-2011 12:10 AM
