How Many Tons Would You Guess This Central AC Unit Is? Outdoor Portable Generator - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By user_12345a
Old 08-21-2020, 09:49 AM   #1
Rewards Points: 510
How many tons would you guess this Central AC Unit is? Outdoor portable generator
How many tons do you think this AC Unit is?
I ask because I need to know what minimum wattage would power this and my
entire house as far as what portable generator I would need.
I am eyeing this 17500w Generac outdoor generator.
https://www.generac.com/all-products...eries/gp17500e
Thoughts?
BTW the Central Air Unit is the following dimensions: 36 inches H x 36 inches D x 35 inches W
How many tons would you guess this Central AC Unit is? Outdoor portable generator-unnamed-2-.jpg   How many tons would you guess this Central AC Unit is? Outdoor portable generator-unnamed-3-.jpg
HTFreak is offline   Reply With Quote
Old 08-21-2020, 10:11 AM   #2
user_12345a's Avatar
Rewards Points: 48
Re: How many tons would you guess this Central AC Unit is? Outdoor portable generator
4 ton
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 08-21-2020, 10:22 AM   #3
Rewards Points: 3,258
Too bad you can't see the max circuit amps, but I'll bet you could find that in a manual online or something.
Using the minimum amps of 26A @ 240v you're at 6,240 watts. So that's minimum. Not sure how that relates to recommended loading of generators, but there's at least a ballpark idea of what kind of power you need.
Of course the best option is to measure the current when it's working hard and just see.
To the optimist, the glass is half-full.
To the pessimist, the glass is half-empty.
To the engineer, the glass is twice as big as it needs to be.
DIYOkie is offline   Reply With Quote
Old 08-21-2020, 10:30 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 42
Originally Posted by user_12345a View Post
4 ton
Based on the model number, I agree, 4 tons. The 48 in the model number means 48000 BTUs. 12000 BTUs per ton
Sent from my Lenovo TB-X606F using Tapatalk
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 08-21-2020, 11:03 AM   #5
Rewards Points: 48
Generator needs to be able to handle the max starting amps which can be 4 to 6 times running current.
doesn't necessarily mean it needs to be able to handle over 100 amps continuous, but it needs to be able to handle that kind of current momentarily.
DIYOkie likes this.
