How To Fix Disconnected Ductwork? - HVAC - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 3 Post By Windows on Wash
  • 1 Post By Trudy23
  • 2 Post By Nealtw
Old 03-28-2020, 03:46 PM   #1
Rewards Points: 8
How to fix disconnected ductwork?
Hello- Can somebody please tell me how to fix the pictured disconnected vertical ductwork? I'd be grateful.
Trudy23 is offline   Reply With Quote
Old 03-28-2020, 03:50 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 766
Re: How to fix disconnected ductwork?
It's not disconnected. It's an expansion joint.
If you feel a bit of air leakage there, that is normal. Should only be a bit though.
user_12345a, Nealtw and Gwing21 like this.
Old 03-28-2020, 03:55 PM   #3
Rewards Points: 8
That's great. Thank you so much for your reply and help! It's much appreciated.
Windows on Wash likes this.
Old 03-28-2020, 04:51 PM   #4
retired framer
Rewards Points: 282
Is it ripped open?
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 03-28-2020, 05:07 PM   #5
Rewards Points: 8
Hi - Thank you for replying. It's not ripped as far as I can tell.
Old 03-28-2020, 05:09 PM   #6
retired framer
Rewards Points: 282
They are nice for stopping any vibration noise from the furnace.
Windows on Wash and Trudy23 like this.
figure 7-14
Old 03-28-2020, 07:07 PM   #7
sktn77a's Avatar
Rewards Points: 1,014
There should be a vinyl collar between the two metal duct ends if it's a flex/expansion joint.
sktn77a is offline   Reply With Quote
Old 03-29-2020, 10:08 AM   #8
Rewards Points: 8
Thank you! That's helpful to know.
