Hot Air From A/c - HVAC - DIY Chatroom Home Improvement Forum
Old 03-27-2020, 08:21 PM   #1
Rewards Points: 12
Hot air from a/c
I bought a house in February (had it inspected beforehand), but the first day I try to use the A/C it pushes out hot air. I have a Honeywell thermostat (no wifi) and a Goodman heat pump/air conditioning unit. Any suggestions to fix this? Am I destined to have to contact the HVAC contractor who installed the unit? Thanks!
tubbfan is offline   Reply With Quote
Old 03-27-2020, 09:13 PM   #2
Rewards Points: 106
Re: Hot air from a/c
Is the outside condensing unit running: compressor and fan?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 03-27-2020, 09:17 PM   #3
Rewards Points: 12
Yes, it is running
Old 03-27-2020, 09:28 PM   #4
Rewards Points: 758
Is the compressor and condenser fan running or just the fan?
roughneck is online now   Reply With Quote
Old 03-27-2020, 09:41 PM   #5
Rewards Points: 12
how do I know if both are running? The fan is running.
Old 03-27-2020, 09:42 PM   #6
Rewards Points: 758
Should be able to hear the compressor running.
Is the suction line cold?
Old 03-27-2020, 09:58 PM   #7
Rewards Points: 12
does it make a different sound than the fan? How do I distinguish?
Old 03-27-2020, 10:24 PM   #8
Rewards Points: 758
Compressor is a distinctive sound, kinda hard to miss. Different then the airflow sound of the fan.
Old 03-27-2020, 10:30 PM   #9
Rewards Points: 12
I have two units. One looks like an a/c compressor. It is not running and the lines are not cold. The other unit's fan is running, but in enclosed so I cannot check any lines.
Old 03-27-2020, 10:33 PM   #10
Rewards Points: 758
So you have 2 different systems in the house, a packaged unit and a split system?
And the split is not running?
If the compressors running in the split and the lines are warm then it’s likely a low charge issue and you’ll need a tech to look at it.
If the compressors not running we will need to determine why that is.
Old 03-27-2020, 10:35 PM   #11
Rewards Points: 12
of course, this would happen on a weekend. . .
Old 03-27-2020, 11:08 PM   #12
Rewards Points: 758
May still be able to figure out what’s going on, or at least diagnose if it’s a refrigerant issue or electrical problem.
Old 03-27-2020, 11:10 PM   #13
user_12345a's Avatar
Rewards Points: 92
you said heatpump. (s ?)
could they be running in heating instead of cooling mode - maybe stats were changed incorrectly.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 03-27-2020, 11:13 PM   #14
Rewards Points: 402
Sounds as if the auxiliary heat may be on while in the cooling mode. I've heard of stranger things.
Old 03-27-2020, 11:44 PM   #15
Rewards Points: 92
could be that. good to call a tech and get eveything checked after buying a house.
