Honeywell Tstat Error With Outdoor Temperature Sensor - HVAC - DIY Chatroom Home Improvement Forum
Old 04-07-2020, 08:57 AM   #1
Rewards Points: 266
Honeywell Tstat error with outdoor temperature sensor
Hello! Trying to figure out why the Honeywell thermostat RTH9585WF would be displaying outdoor temperature sensor error where it normally reads outdoor temp. Any ideas? Heat pump combo is about 6 years old. Thanks!
bluefish7 is offline   Reply With Quote
Old 04-07-2020, 12:09 PM   #2
sktn77a's Avatar
Rewards Points: 1,022
Re: Honeywell Tstat error with outdoor temperature sensor
I believe your thermostat doesn't have an external temperature sensor but gets the temperature from the Honeywell website (using your zip code provided when you registered it). Maybe there's a connectivity issue?
Edit: Not sure how you'd confirm this other than calling Honeywell (?)
sktn77a is offline   Reply With Quote
Old 04-07-2020, 03:42 PM   #3
An old Tradesmen
Rewards Points: 94
Has someone been in the installer menu, and set it to look for an outdoor sensor.
Old 04-07-2020, 05:06 PM   #4
Rewards Points: 266
I don't believe so, is it an easy fix?
Old 04-07-2020, 05:28 PM   #5
user_12345a's Avatar
Rewards Points: 64
The rth series thermostats don't normally support an outdoor sensor - does the manual mention it?
did it work before?
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 04-07-2020, 05:50 PM   #6
Rewards Points: 266
Yes it has historically just displayed the outdoor temp, presumably through Accuweather and the wifi is currently working
Old 04-07-2020, 05:54 PM   #7
Rewards Points: 64
okay so it doesn't have a sensor, it gets the temp from the internet.
if the stat isn't using the outdoor temp reading for any real function, i wouldn't bother trying to get it back.
otherwise...
check the settings and manual.
you may need to call honeywell support.
Old 04-08-2020, 03:34 AM   #8
An old Tradesmen
Rewards Points: 94
You can go into the installer menu and check to see if its been changed. I believe some of the older models of that stat gave the option of a sensor, or wifi temp.
