HONEYWELL Thermostat Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 03-29-2016, 07:53 PM   #1
Rewards Points: 2
HONEYWELL thermostat wiring
I just bought a RTH221 honeywell thermostat to replace my old T6575D1009 model.
i am trying to connect wires, but i don't have the G wire.
i have blue and other wires.
can someone tell me how to do it correctly?
thanks!
HONEYWELL thermostat wiring-photo-2016-03-29-11-31-59-am.jpg   HONEYWELL thermostat wiring-photo-2016-03-29-8-43-36-pm.jpg
morngon is offline   Reply With Quote
Old 03-30-2016, 12:21 AM   #2
Re: HONEYWELL thermostat wiring
1. You mounted the thermostat plate up side down.
2. Your old t-stat has atypical wiring for a unit with atypical controls. Going by letters could get you in deep trouble.
The way the unit it operates is most likely different from a basic 1 stage gas furnace/ac - the stat must be configured to energize the right terminals in each mode of operation.
For example most t-stats don't directly impact fan speed, yours does. In most setups G is the fan terminal - the fan speed selection is based on the mode of operation.
WARNING: I am not in the business of any trade or topic I give advise on. Follow the advice I post at your own risk. I only have previous diy experience plus good knowledge of theory.
user_12345a is offline   Reply With Quote
Old 03-30-2016, 12:30 AM   #3
Best bet is to get the model number of the old stat and cross reference it. You won't find the right stat at a retail chain.
Old 03-30-2016, 04:55 AM   #4
An old Tradesmen
Rewards Points: 7,418
Whoa, stop. Your old thermostat is a line voltage thermostat for fan coils. That new RTH221 is a low voltage/24 volt thermostat. Can't be used on your system.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
gregzoll (03-30-2016), supers05 (03-30-2016)
Old 03-30-2016, 06:10 AM   #5
Rewards Points: 6,652
What is wrong with the existing thermostat? There is a reason why Honeywell.com offers a "Find replacement" option on their website. If the current one is no longer working, you need the TB6575A1000/U from Honeywell to replace it. https://customer.honeywell.com/en-US...=TB6575A1000/U
Old 03-30-2016, 06:14 AM   #6
I am beginning to wonder if people just rip the packaging open and toss everything. There is a reason why they come with the books. Before I even install any thermostat for someone that asks me to do it for them, I an sitting with the book and either a cup of coffee or a beer to familiarize myself with it.
It is neat that of course Honeywell does have a great way for people that want to change their thermostat, to be able to find a match. I am thinking that the OP was walking around the Big Box and grabbed the first one.
When I stopped by the local Electrical warehouse this past week to pick up a new disco for my outdoor A/C unit, because of course you cannot just buy the guts, you have to buy the whole box. They had a whole three shelves of nothing but Honeywell Thermostats.
Old 03-30-2016, 06:28 AM   #7
Rewards Points: 18
Why does that link not work? When I click on it I get an error message?
Sent from my LG-D415 using Tapatalk
jeffmattero76 is online now   Reply With Quote
Old 03-30-2016, 06:41 AM   #8
Probably because you are trying to access it from the Tapatalk app. Download Chrome if you do not already have it and set Tapatalk to use it, instead of the Tapatalk app for web browsing.
The Following User Says Thank You to gregzoll For This Useful Post:
jeffmattero76 (03-30-2016)
Old 03-30-2016, 06:47 AM   #9
Rewards Points: 18
Thanks.
The Following User Says Thank You to jeffmattero76 For This Useful Post:
gregzoll (03-31-2016)
Old 03-30-2016, 07:21 AM   #10
Rewards Points: 18
While we are on thermostats... I have two gas hot air furnaces un my home and two Honeywell 7 day programmable thermostats that were installed by a local, well known hvac firm. When first installed by the owner, both t stats worked fine. The owner died and the son took over the business. The spn worked with the dad for a few years. In any case, after coming over to fo a checkup and repair, when i put the fan on ON rather than AUTO the blower does not turn on. I hadn't moticed it until months later since I only use that feature in the summer and the repair was done in October. Can you tell me which wire goes to which terminal on the board? At the t stat end everything seems to be wired correctly. The furnace is a Ruud.
Old 03-30-2016, 07:58 AM   #11
Hvac Pro
yuri's Avatar
Rewards Points: 1,322
G is the wire that turns on the fan and may be broken at the board if it got bumped during the checkup. Check the G terminal/wire.
The Following 2 Users Say Thank You to yuri For This Useful Post:
gregzoll (03-31-2016), jeffmattero76 (03-30-2016)
Old 03-30-2016, 08:01 AM   #12
Rewards Points: 18
Old 03-30-2016, 08:30 AM   #13
Hvac Pro
yuri's Avatar
Yur Welcome
Old 04-03-2016, 07:07 AM   #14
Rewards Points: 18
Yuri to be clear the blower works as it should when in the AUTO position. However, when in the ON position it doesn't come on. Is that still the G wire?
Old 04-03-2016, 07:56 AM   #15
Hvac Pro
yuri's Avatar
Yes. The Y wire turns on the AC and fan at the same time and the heat does the same.
Installing a Honeywell RTH2300B thermostat to a gas furnace. Have the standard WYRG wiring. Devan813 Electrical 3 12-25-2011 05:19 PM
heat pump wiring problem - new thermostat tygrr94 HVAC 8 01-17-2011 08:18 PM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 04:19 PM
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 04:43 AM
