Heat Radiator - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 03-17-2020, 08:44 AM   #1
Rewards Points: 92
heat radiator
I live in the Dallas area. I was thinking on switching to a heat radiator and not depending on HVAC. I recently came from Europe and I had one of those radiator in my room. It felt nice and toasty. Just loved it. I notice places up north have them in the US. Can anyone help me find company in Texas that install or work with them?
Gabe86 is offline   Reply With Quote
Old 03-17-2020, 08:56 AM   #2
Rewards Points: 4
Re: heat radiator
You would have to change your whole heating system. This is a hydronic heating system where the heat is supplied by hot water or possibly steam.
If you have an open basement or crawl space and a 1 floor house, it would be a relatively easy swap, just expensive as you would need to add a heat source, like a boiler. and run all new piping to each radiator.
Check with any plumber who does HVAC, or pretty much any HVAC and say that you want hydronic radiant heat.
And be prepared for a big bill.
The only stupid question is the one you DON'T ask!
ktownskier is offline   Reply With Quote
Old 03-17-2020, 09:48 AM   #3
Rewards Points: 724
Re: heat radiator
Do you have hydronic heating now?
Dallas doesn’t have a lot of basements. And is primarily a cooling climate. You’ll still need forced air cooling in that area and the ROI wouldn’t not be there for installing a hydronic heating system.
Hydronic heating isn’t near as popular in the US as it is in other countries. And the areas you see it are primarily to the north/northeast.
roughneck is online now   Reply With Quote
Old 03-17-2020, 11:14 AM   #4
Rewards Points: 92
Re: heat radiator
no i dont have any hydronic is a old home. and the only A/C it currently has is the one you hang out from the window. im going to tear down the old walls off and add a mini split i like them a lot more compare to the HVAC. but i figure the cold season is what need is a radiator from my experience with them in Ukraine.
Old 03-17-2020, 11:15 AM   #5
Rewards Points: 92
Re: heat radiator
Thank i will find a local HVAC place and make some calls see if they do this kind of service.
Old 03-17-2020, 11:20 AM   #6
Rewards Points: 260
Re: heat radiator
PLEASE- PLEASE, no further discussion of cost.
Old 03-17-2020, 11:22 AM   #7
Rewards Points: 92
Re: heat radiator
?? well if any one know a tech in Dallas let me know or send a links this would be helpful get a expert to take a look at my home.
Old 03-17-2020, 11:52 AM   #8
Rewards Points: 724
Re: heat radiator
Talk to your friends, family or coworkers. See if anyone comes recommended.
A minisplit heat pump could easily heat your home.
You’ll need someone that greatly understands hydronics, not so easy in the US especially in a cooling heavy market.
Old 03-17-2020, 11:55 AM   #9
Rewards Points: 92
Re: heat radiator
Well that one reasons why i came on here not every one would know this. again texas is know for HVAC not radiators im sure someone or few hand full of people might have a radiators in their homes
Old 03-17-2020, 12:11 PM   #10
Rewards Points: 92
Re: heat radiator
Does this save a lot on electricity bill on
Convection Heater?
Old 03-17-2020, 12:21 PM   #11
Rewards Points: 724
Re: heat radiator
I don’t see what your asking about.
Is that an electric powered unit?
Old 03-17-2020, 12:22 PM   #12
Rewards Points: 92
Re: heat radiator
Old 03-17-2020, 12:23 PM   #13
Rewards Points: 92
Re: heat radiator
Old 03-17-2020, 12:25 PM   #14
Rewards Points: 5,134
Re: heat radiator
Electric panel heaters are available.
Old Thomas is offline   Reply With Quote
Old 03-17-2020, 12:31 PM   #15
user_12345a's Avatar
Rewards Points: 48
Re: heat radiator
Hydronic is a total waste of money in texas.
If I had to guess at cost, i would say $20 to $30k+ for a system used a few weeks at most each year.
Stay away from straight electric - costs too much to run.
Can put in a mini-split heatpump system and be done with it. One outdoor unit connected to multiple heads.
They heat very efficiently in mild climates.
Get rid of the crappy window units and get heat as well - kill two birds with one stone.
Don't do convenctional forced air unless the air ducts don't have to be in a hot attic.
You can also look at gas wall furnaces if you don't like forced air style heating systems.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
