Heat Circulation - Propane Stove - HVAC - DIY Chatroom Home Improvement Forum
Old 11-19-2013, 07:57 AM   #1
Hey Guys. Need some advice. I have a propane stove in the finished family room of split entry home. The home is electrically heated, so I want to use the stove to supplement. The problem is that the heat never leaves the family room. I suspect it is because of the way the basement was finished, so I am trying to figure out if there are modifications I can do to get better circulation.
There is no venting between floors. There are no doors around the stairs to prevent cold air from moving down stairs. While upstairs is fairly open, downstairs is a hallway with rooms (usually closed except for the family room). The stove is at the far end of a 12'x20' room where the only opening is a 36"x80" doorway (no door) at the opposite (near) end. The 12' wall nearest the doorway backs onto the stairwell.
When the stove runs on its lowest setting, the family room becomes very warm, anything higher becomes unbearable. But, as soon as you pass through the doorway, you're hit with cold air. There seems to be no transfer of heat through the opening.
So, I am been wondering if I should consider venting between floors (with fire dampeners) or opening up the wall that backs onto the stairwell to increase airflow. Also open to other suggestions. Thanks in advance.
gdoucette is offline   Reply With Quote
Old 11-19-2013, 08:17 AM   #2
Rewards Points: 17,826
Add another heater up stairs.
Old 11-19-2013, 08:26 AM   #3
Which helps with my question how?
Old 11-19-2013, 11:10 AM   #4
FClef's Avatar
Rewards Points: 160
What kind of "stove" is this heater you are talking about?
"Human beings can always be relied upon to assert, with vigor, their God-given right to be stupid"
Dean Koontz - Seize The Night
FClef is offline   Reply With Quote
Old 11-19-2013, 11:22 AM   #5
It's a direct vent pedestal fireplace
Like this
http://www.homeclick.com/majestic-rf...p-496663.aspx#.
Old 11-19-2013, 04:52 PM   #6
An old Tradesmen
Rewards Points: 7,444
Might want to try cutting a vent into the ceiling to go to the upper floor. See if that gets you enough heat transfer. If not, then opening up the wall at the steps is an option.
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 03:59 AM
Heat pump is not running on Heat mode frank06 HVAC 17 03-13-2012 03:34 AM
converting to propane heat dan l HVAC 1 01-07-2011 06:06 PM
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 05:51 PM
propane heat sharpeidar HVAC 1 12-04-2007 07:17 PM
