Hard Start Kit For 1 Year Old 5 Ton Amana AC - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 04-04-2020, 09:13 PM   #16
Rewards Points: 68
Happy to report that the 3-2-1 kit dropped my starting amperage from 49 to 34 amps. Shouldn't be a problem starting this 5 ton with a 12k watt generator
Hard Start Kit for 1 year old 5 ton Amana AC-20200404_141923_1586052729957.jpg
user_12345a likes this.
anthony21078 is offline   Reply With Quote
Old 04-05-2020, 05:11 AM   #17
An old Tradesmen
Rewards Points: 98
Re: Hard Start Kit for 1 year old 5 ton Amana AC
A hard start kit doesn't actually lower the starting amp draw. It does shorten the duration that the compressor draws that amperage though, and often it is so short. That many digital meters can't read the true amp draw.
Old 04-05-2020, 11:46 PM   #18
Rewards Points: 68
I have read that this is likely the case. However, if my meter was reading 49 amps prior to the hard start kit and 34 now, is it still safe to say that the initial draw has been reduced? Or perhaps like you said, its so short that the generator may not even feel the surge if the draw is near the generators max capacity?
Old 04-05-2020, 11:51 PM   #19
user_12345a's Avatar
Rewards Points: 64
The hard start shortens the surge so the generator doesn't get overloaded and voltage output drops, preventing compressor from starting properly.
The maximum current is always rated locked rotor current - it drops as the motor speeds up.
The hard start increases torque so it gets up to speed faster.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 04-06-2020, 04:09 AM   #20
An old Tradesmen
Rewards Points: 98
It might handle the shorten draw time, it might not. Can't tell from my side of the internet.
