Gravity Boiler - HVAC - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By 57TinkerMan
  • 2 Post By beenthere
Old 10-12-2018, 07:35 PM   #1
Rewards Points: 928
Gravity boiler
Anyone know anything about gravity boilers? I bought a house this August with an old, old coal fired gravity boiler which has since been converted to natural gas. Definitely going to change it, but I need to limp through this first winter.
I suspect some of the radiators need bleeding, as only the bottom is warm. Kinda wondering how to go about this. It doesn't have a fill valve which regulates the pressure, just a valve connecting it to the household water. Just open the bleeder and let it fill, then go down and open the valve to the supply and bring the pressure back up? Right now, the pressure gauge says 12 pounds.
Anyway, if anyone can shed some light on this, I'd appreciate it.
Marson is offline   Reply With Quote
Old 10-12-2018, 09:42 PM   #2
Rewards Points: 216
Re: Gravity boiler
You got it, kinda simple. Don't let the pressure exceed 25 psig while filling, the pressure relief valve on the boiler (hope it has one) will open at about 30 psig. Lots of info out there about converting gravity systems to pump systems.
Good luck!
supers05 likes this.
57TinkerMan is offline   Reply With Quote
Old 10-13-2018, 12:48 AM   #3
Rewards Points: 70
Re: Gravity boiler
Don't forget that gravity systems take a long time to change. Starting, warming, and cooling take a long while. I wouldn't be surprised if it took a full a few hours before you felt much warmth up stairs.
Cheers!
supers05 is offline   Reply With Quote
Old 10-13-2018, 05:33 AM   #4
An old Tradesmen
Rewards Points: 7,440
Re: Gravity boiler
Open the bleed valve. When you get no air or water out, close it, and go down to the boiler, and add water until your at 15 PSIG. Then go back up stairs and repeat until you get water out of the air vent. And do this to all upstairs rads, and check the down stairs also.
Then, drain your expansion tank, if it still has the old large steel tank. Its most likely full of water, and your upstairs rads have been acting like an expansion tank.
supers05 and 57TinkerMan like this.
The Following User Says Thank You to beenthere For This Useful Post:
Marson (10-13-2018)
Gravity coal boiler set up? kameljoe21 HVAC 5 01-23-2018 03:17 AM
GAS Boiler short Cycling on and off. Normal Operation ? the punisher HVAC 16 12-15-2015 03:39 PM
New Boiler for an Office - Got Two Quotes, but What Do We Need? Prolow Plumbing 0 09-17-2012 06:10 AM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
retrofit pump on gravity boiler InquiringMind HVAC 3 07-31-2009 02:20 PM
