Goodman GSX130241DA Cooling Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 07-08-2020, 08:13 AM   #1
Rewards Points: 8
Goodman GSX130241DA cooling problem
The AC unit and condo were new 6 years ago. I started working nights last winter and now come summer and 90F+ daytime temps i'm finding the AC is not keeping up.
1200 sq ft top/2nd floor condo will be around 75 when I get home at 6am. I'll turn it down to 68 when i go to sleep at 9am. After 6 hours or so of sleep I get up and the condo will only be down to around 72.
I've never had the AC serviced professionally (or done anything but change filters), am I overdue for basic maintenance or maybe a bigger issue?
bluespark is offline   Reply With Quote
Old 07-08-2020, 08:19 AM   #2
Rewards Points: 738
Re: Goodman GSX130241DA cooling problem
Could be freezing up, low on refrigerant, have a dirty condenser or something else.
You are trying to pull the space temperature down coming into the heat of the day.
roughneck is online now   Reply With Quote
Old 07-08-2020, 08:31 AM   #3
Rewards Points: 8
The unit is on the north side of the building so it only gets minimal morning sun. I'm in N colorado so the real heat comes on a few hours later, maybe 11am
Old 07-08-2020, 08:36 AM   #4
Rewards Points: 738
Is the unit able to maintain temperature during the heat of the day?
I’d definitely do a PM on it, clean the coils and check everything out
Old 07-08-2020, 08:49 AM   #5
Rewards Points: 8
Condo is definitely not getting to set point. I'll set up a PM
Old 07-08-2020, 10:35 AM   #6
Rewards Points: 344
First to check is the Delta-T number (room temp minus cold AC vent air temp)
Normal range is 16-20.
clocert is offline   Reply With Quote
Old 07-08-2020, 11:00 AM   #7
dj3
Rewards Points: 194
Yes, you might benefit from a tuneup/checkup, freon check and cleaning.
dj3 is offline   Reply With Quote
Old 07-09-2020, 05:18 AM   #8
An old Tradesmen
Rewards Points: 98
Slow down. Try setting your thermostat to 68 at 7 AM. It might get down to 68, 69, or maybe 70 by 3PM then.
Many A/Cs can take an hour or 2 to reduce the temp 1 degree.
Remember, you have heat gain from the condo below you, and the hot roof.
Old 07-09-2020, 07:36 AM   #9
Rewards Points: 8
It has always warmed or cooled pretty quickly until recently. 1200 sqft place w/ 1 bedroom isolated.
Old 07-09-2020, 10:37 AM   #10
NYPR
Rewards Points: 6
You say it's been 6 years w/o a PM? You can guarantee both coils are dirty. The units need to breathe. Never let it go that long, you'll end up spending big bucks on major repairs.
You're dropping the temp 7 degrees and expecting it to cool down during the hottest time of day. Set your thermostat to 70 or 72 when you leave, then you're only dropping it 2 to 4 degrees when you come home. You end up paying for the heat load when you have a big difference in temp settings. I keep mine at 72 night and day, it's less of a load for the unit to maintain, hence less cost for electricity.
mcarter4457 is offline   Reply With Quote
Old 07-09-2020, 03:39 PM   #11
An old Tradesmen
Rewards Points: 98
Post a pic of the outdoor coil.
