Goodman Furnace 10 Code - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By beenthere
Old 01-28-2020, 02:31 PM   #1
Rewards Points: 6
goodman furnace 10 code
I just installed a new nat gas goodman furnace and it operated fine for a few weeks then it shut down showing a 10flash on board, no 10 flash in manual! I did finally check fuse and it was blown, replaced and everything is fine now. very odd as board should be dead if fuse was blown?
joeboy26301 is offline   Reply With Quote
Old 01-28-2020, 02:50 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 162
Re: goodman furnace 10 code
The board may have a code for a blown fuse or lack of 24 volts. Most do.
There should be a sticker on the inside of one of the doors or the code is in the wiring diagram on those doors.
Old 01-28-2020, 05:31 PM   #3
Rewards Points: 14
Check new literature for your model off the goodman site, updates flash codes all the way up to 12 flashes. Would it be the GMES series ?
Sent from my SM-J337A using Tapatalk
diy84 is offline   Reply With Quote
Old 01-29-2020, 06:59 AM   #4
Rewards Points: 6
Yes GMES series, the manual with furnace only goes to 9flash thanks for response
Old 01-29-2020, 08:14 AM   #5
Rewards Points: 14
Whatever shipped with the furnace is outdated, on the Goodman website find your model and download latest paperwork. They even issued a service bulletin.
Old 01-29-2020, 08:37 AM   #6
Rewards Points: 6
Thanks, even codes on blower door only go to 9...I looked on their website and couldn't find that info either, I scratched my head awhile before checking fuse! older furnaces the board was dead when fuse is blown?
Old 01-29-2020, 03:14 PM   #7
An old Tradesmen
Rewards Points: 54
https://www.goodmanmfg.com/pdfviewer....pdf?view=true
I think its page 15.
joeboy26301 likes this.
