Furnace High Efficiency Vent Size - HVAC - DIY Chatroom Home Improvement Forum
Old 03-27-2020, 09:00 PM   #1
Rewards Points: 8
Furnace high efficiency vent size
Hi,
I had my hvac replaced recently and I was wondering if a 2" pvc is enough ?
the furnace exhaust diameter is 2", my vent run horizontally for 13ft.
Also the vent is really close to the ground outside like 4inches (90 elbow is facing the ground).
Sylvain C is offline   Reply With Quote
Old 03-27-2020, 09:29 PM   #2
Rewards Points: 758
Re: Furnace high efficiency vent size
Exhaust needs to be above the snow line.
2” is ok to certain lengths. It should state this length in the install manual.
It is PVC correct?
roughneck is offline   Reply With Quote
Old 03-27-2020, 10:33 PM   #3
Rewards Points: 8
2 is ok to certain lengths. It should state this length in the install manual.
It is PVC correct?
Yes pvc, I dont have the manual. Then I will probably relocate the vent higher
Old 03-27-2020, 10:34 PM   #4
Rewards Points: 758
What is the make and model number of the furnace?
Old 03-28-2020, 05:54 PM   #5
Rewards Points: 1,482
Check the manufacturer's specifications and follow them. With a high efficiency furnace what you have is not so much an exhaust line as a condensate line and so the pipe cannot be level to function properly.
Calson is offline   Reply With Quote
Old 03-28-2020, 07:05 PM   #6
sktn77a's Avatar
Rewards Points: 1,028
The PVC vent pipe size depends on the size of the furnace and the length of the run. This will be detailed in your installation instructions.
sktn77a is offline   Reply With Quote
