Furnace Blower Motor Rebuild - HVAC - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 2 Post By zootjeff
  • 1 Post By de-nagorg
  • 1 Post By user_12345a
  • 3 Post By zootjeff
Old 11-21-2016, 07:44 AM   #1
Rewards Points: 444
Furnace blower motor rebuild
I have a 92% Trane furnace with a noisy blower on the variable speed fan. I pulled the blower and took out the permimant magnet rotor. You can tell the bearings are shot on the shaft end.. Does anyone have experience pulling bearings that could give me advice? Is there a jig I can buy for this or do I need to take it to a machine shop?
zootjeff is offline   Reply With Quote
Old 11-21-2016, 08:52 AM   #2
JUSTA MEMBER
Rewards Points: 4,320
Re: Furnace blower motor rebuild
There are bearing pulling tools.
Sold for automotive , and other bearings.
Have you looked for them?
ED
de-nagorg is online now   Reply With Quote
Old 11-21-2016, 09:12 AM   #3
Rewards Points: 568
Just replace the motor
BayouRunner is offline   Reply With Quote
Old 11-24-2016, 04:55 PM   #4
Rewards Points: 444
I wasn't able to find this motor for less than $500... I've ordered the new bearings and successfully pulled the old ones from the rotor. Looks like it is going to cost me about $60 for new bearings and tools..
SeniorSitizen and de-nagorg like this.
Old 11-24-2016, 07:37 PM   #5
user_12345a's Avatar
Rewards Points: 3,068
you may be able to buy the motor part without the controller.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 11-24-2016, 07:40 PM   #6
Rewards Points: 444
Is there a reason I should toss a perfectly good motor that just needs new bearings?
Old 11-24-2016, 07:42 PM   #7
Rewards Points: 444
Here is the motor..
Old 11-24-2016, 09:27 PM   #8
JUSTA MEMBER
NOT in my world.
ED
ChuckF. likes this.
Old 11-24-2016, 09:33 PM   #9
if you can fix the motor, you should.
de-nagorg likes this.
Old 11-25-2016, 05:04 AM   #10
An old Tradesmen
Rewards Points: 9,824
You'll know after you replace the bearings.
Old 12-07-2016, 11:00 PM   #11
Rewards Points: 444
Well crap. The bearings on the motor are 40mm OD and 12.7mm ID. The bearing had a fafnir 203 kd on it.. I ordered that bearing and got a 17mm ID.. Bummer. Any ideas where to go to get a 203kdd (double shield) that has a 1/2" shaft?
Jeff
Old 12-08-2016, 04:33 AM   #12
JUSTA MEMBER
I would think that in Portland, there is a large repair shop for electric motors, that can help you get the correct sizes.
I know that here in the middle of Wyoming that we have 2 electric motor repair shops.
Both are quite busy.
Have you tried to find any help that way?
ED
Old 12-17-2016, 11:00 AM   #13
Rewards Points: 444
OK, I solved the bearing problem. I was trying to order based on the markings on the bearings and that is clearly not the way to do it.
I wound up getting:
6203-ZZ-1/2 Special Size Ball Bearing 1/2x40x12mm Shielded KYK from bearingsdirect.com and they were 10 bucks each plus shipping. Got them and they fit perfectly, and they are double metal shielded just like the ones I pulled off. Now to rebuild the motor and put the furnace back together.
-Jeff
Old 12-28-2016, 11:20 AM   #14
Rewards Points: 444
I reassembled the motor last night and put the the system back together and it runs like a charm. It was very helpful to take pictures of the assembly for taking it all apart so that I could have a reference when putting it back together.
When running heat pump mode it has the highest CFM and that's when the noise was the most annoying from the failed bearings. Now it runs smooth again.
The Following 2 Users Say Thank You to zootjeff For This Useful Post:
de-nagorg (12-28-2016), SeniorSitizen (12-28-2016)
Furnace flame and blower alternate 1harleynut HVAC 7 10-29-2013 08:53 PM
furnace blower won't come on gulleyj HVAC 15 11-11-2012 03:16 PM
Replace furnace or blower agibby5 HVAC 6 07-17-2012 06:17 PM
How much power does a small furnace blower use? Red Squirrel HVAC 10 07-31-2009 09:03 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
