Which Fin Straightener Is Better? - HVAC - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 2 Post By lenaitch
  • 1 Post By yuri
Old 09-04-2019, 03:25 PM   #1
Rewards Points: 466
which fin straightener is better?
pman626 is offline   Reply With Quote
Old 09-04-2019, 06:04 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,560
Re: which fin straightener is better?
They are both good and I own both types.
All depends on the unit and how much access you have as to which works better. Nice to have both.
Old 09-04-2019, 08:30 PM   #3
Rewards Points: 466
which one is better for my monster ?...
I need the faster efficient one.
Is the metal one harder to use? It looks like all the tines are bunched together.
Old 09-04-2019, 10:16 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 924
An intervention? Or a priest?
yuri and Windows on Wash like this.
_________________________________________
Sic Itur ad Astra
lenaitch is online now   Reply With Quote
Old 09-05-2019, 08:33 AM   #5
Hvac Pro
yuri's Avatar
A thin pocket screwdriver/hacksaw blade or butter knife may be your only salvation.
Seriously.
When they get badly bent from hail the only thing to get between them is a screwdriver. Then you can try nudge and work them into a row with the other 2.
Probably the hard plastic one will be better then.
Old 09-06-2019, 09:10 AM   #6
Rewards Points: 80
The plastic ones have specific spacing so you can use the exact right one. It's a bit better on kicked in fins, but like yuri said, it might be just a small pocket screwdriver. Fin after fin..
Cheers!
supers05 is offline   Reply With Quote
Old 09-06-2019, 11:38 AM   #7
Hvac Pro
yuri's Avatar
And if the dog used it for a latrine then forget about the coil, it's shot.
As soon as you wash it the fins will crumble off and same with trying to straighten them.
supers05 likes this.
Old 09-06-2019, 11:24 PM   #8
Rewards Points: 3,408
I like the type with the separate handle and interchangeable heads.
But like yuri said, if the coils damaged from dog urine then there’s no fixing it.
roughneck is online now   Reply With Quote
