Evaporator Coil Cleaning - How Often And How Much - HVAC - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 3 Post By user_12345a
Old 02-04-2020, 09:38 PM   #1
Rewards Points: 336
Evaporator coil cleaning - how often and how much
I got my AC unit checked today. This included hosing down the condenser coils. I have this done once a year.
I have the evaporator coils checked as well and I was told they wouldn't need to be cleaned.
This is a new AC tech and he comes recommended from a number of people in the area. His service call is on the low-end ($50.)
He mentioned cleaning the evaporator coils should they need cleaning will run around $250 which sounds outrageous.
I asked why so pricey and he said it is difficult to clean the evaporator coils.
However, I'm thinking you simply check the coils and if necessary spray a cleaner on them.
Am I missing something?
Or is such a cleaning charge a ripoff?
ken33xx is offline   Reply With Quote
Old 02-04-2020, 09:51 PM   #2
Rewards Points: 754
Re: Evaporator coil cleaning - how often and how much
Should be checked at least once per year.
They can get pretty dirty depending on the setup of the equipment.
They can be difficult to clean properly.
Once they get really bad you have to pump the system down, remove the coil, and take it outdoors to use a hose and chemical cleaner.
roughneck is online now   Reply With Quote
Old 02-04-2020, 10:01 PM   #3
user_12345a's Avatar
Rewards Points: 2,622
If the filter is doing its job* and air isn't leaking around it, the evap should never need to be cleaned. It's not part of normal maintenance.
*Needs to at least merv 6, some say at least merv 8. Proper filter sizing is important to be able to use something decent without reducing airflow too much.
$250 sounds cheap for evap cleaning if it has to be removed to access the inlet side.
raylo32, SeniorSitizen and cheeno like this.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 02-04-2020, 10:36 PM   #4
Rewards Points: 4,278
I agree with post #3. Keep good filters in it and it will last the life of the system. I clean my own condenser regularly but without coil cleaner. You have to be careful with coil cleaner or it will eat up the fins.
Old Thomas is offline   Reply With Quote
Old 02-04-2020, 11:15 PM   #5
Rewards Points: 336
Thanks everyone.
You've been a great help.
Old 02-05-2020, 09:52 AM   #6
raylo32's Avatar
Rewards Points: 1,760
This is also what I have seen in my admittedly narrow experience. The coil in my system developed a leak when it was about 15 years old. I had been using the pleated filters in the mid range, like MERV 6 to 8 or equivalent for that entire time. When I replaced the coil I saw that the original one was really pretty clean. I'm sure this varies a lot based on how a system is installed, set up and maintained. But IMO with a little due diligence they should not really need cleaning.
Live long and prosper.
raylo32 is online now   Reply With Quote
Old 02-05-2020, 09:55 AM   #7
raylo32's Avatar
Once upon a time I believe it was BeenThere who recommended cleaning the condenser coils with Simple Green or similar. I have been doing that every couple of years with great results. My outside condenser is a builder's grade Bryant 3 1/2 ton that is ~24 years old and still going strong.
Old 02-05-2020, 10:17 AM   #8
Rewards Points: 6,554
Ours was put in service in 1983 and has never been inspected. I have determined that with a good filter system - as user mentioned - I or my tech can pull the blower for oiling every x number of years and if it never needed cleaning the evap coil doesn't need cleaning either. The ole girl still has a respectable Delta T of 20 on a good day and 17 on a bad day.
Old 02-05-2020, 11:36 AM   #9
surferdude2's Avatar
Rewards Points: 750
@SeniorSitizen That's a normal variation of ∆ T since humidity is a factor. You have a healthy system if you get 20 under normal humidity.
surferdude2 is offline   Reply With Quote
The Following User Says Thank You to surferdude2 For This Useful Post:
SeniorSitizen (02-05-2020)
Old 02-05-2020, 12:40 PM   #10
Sometimes a 15F drop at normal humidity can be okay - it depends on the fan speed.
A 20f drop can not be okay if airflow is low and it's covering up a refrigeration problem.
More information is required to see if a system is working properly.
Old 02-06-2020, 04:40 AM   #11
An old Tradesmen
Rewards Points: 9,502
Depends on what type of cleaning is done.
Sometimes just spraying an evap coil cleaner on the air discharge side doesn't clean the air inlet side.
So sometimes you end up cutting open the return duct to spray the coil, and possibly even have to comb the dirt off/out.
Old 02-06-2020, 02:04 PM   #12
Rewards Points: 750
I can assure you that having to pull the evap coil and cleaning it isn't outrageously priced at $250. It's what I'd call hard earned money.
If done properly, it will take 3~4 hours maybe longer. It requires extracting the charge and disconnecting the refer lines, drain line and whatever else may be in the way.. maybe the flue pipe and humidifier bypass duct. Then taking the coil outside and cleaning it. Then installing it and connecting all the lines and ducting back. Maybe installing a filter drier. Then evacuating the system (an hour minimum. longer is better, using micron gauge). Then recharging the system and checking the operation. You'll be getting your money's worth.
That said, don't do it unless the tech says you need it. Most won't push for that kind of work.
