Evap Cooler Size Conversion? - HVAC - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By surferdude2
Old 05-03-2020, 07:37 PM   #1
Rewards Points: 6
Evap cooler size conversion?
Maybe a dumb question but I am replacing the swamp cooler on my Moms home. Her friend gave her a new one with a 20" vent but the problem is that her old one was an 18" vent. I am totally lost on how to convert this efficiently or if it can be done? I have very limited construction experience, I am just trying to save her some money. Does anyone make a conversion kit? Any advice is appreciated. Thanks in advance.....
butler33 is offline   Reply With Quote
Old 05-03-2020, 08:56 PM   #2
surferdude2's Avatar
Rewards Points: 936
Re: Evap cooler size conversion?
Not knowing the exact situation, I'll take a shot in the dark and say you can improvise a duct reducer using some medium weight flashing metal bent into the configuration of angle stock. Allow the flange side to be wide enough to screw onto the swamp cooler housing and provide enough connector flange to engage the existing duct. Cut and bend the corners to size that accordingly. Screw it onto the cooler and the existing duct and apply butyl rubber calk to make it water tight. RTV is OK if you can't get butyl rubber.
A sheet metal shop could make this for you and it would look better. lol
If instead you have a bottom discharge unit, you can likely just set it down on the raised duct and forget the above method.
Swamp coolers aren't all that particular about a little duct reduction.
butler33 likes this.
surferdude2 is offline   Reply With Quote
Old 05-03-2020, 10:12 PM   #3
Rewards Points: 936
Check out some roof to wall flashing... maybe one of the big box stores will have something you can use. You could rework it easy for your use.
Roof to wall flashing example
Old 05-03-2020, 10:18 PM   #4
Rewards Points: 6
Appreciate the recommendation. I will look into both options.
Old 05-03-2020, 10:34 PM   #5
Rewards Points: 936
It's not a first class fix but it's something you or any handyman can pull off with some tin snips and common hand tools without having to spend big bucks to do it professionally.
If the new blower delivers too much air for your mom's liking, check the motor to see if it has an adjustable sheave... that can be set for lower speed operation if need be.
Good luck.
Old 05-03-2020, 10:40 PM   #6
Rewards Points: 6
I think I have an idea how to make it work, following your advice. I greatly appreciate the help......
