Electric Boiler...is My Pressure Too Low? - HVAC - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Old 01-06-2018, 11:25 AM   #1
Guest
Seems like I have to put my heat up to at least 70 degrees to get radiator in attic warm. My boiler is showing 10 PSI when it's running or sitting idle. Too low? How do I increase it? Picture provided, do I turn that screw on top to increase PSI? Counter-clockwise?
Electric boiler...is my pressure too low?-img_20180106_122336784_1515259558889.jpg
489537 is offline   Reply With Quote
Old 01-06-2018, 12:08 PM   #2
Rewards Points: 1,080
Re: Electric boiler...is my pressure too low?
On a PRV turn clockwise to increase pressure.
Wilbits is offline   Reply With Quote
Old 01-06-2018, 12:13 PM   #3
Guest
In the picture provided, is that even the right thing I took a picture of? It's as simple as turning that screw on top? While the boiler is running? Here it is from another angle.
Electric boiler...is my pressure too low?-img_20180106_122329083_1515262605499.jpg
Old 01-06-2018, 12:33 PM   #4
The only thing I can tell is it's a PRV. Can you post pics from further back ?
Old 01-06-2018, 01:35 PM   #5
An old Tradesmen
Rewards Points: 7,422
Loosen nut, turn screw in, wait to see if pressure rises to whee you want, if not, turn in further, if it did. Tighten nut.
Raise the pressure to between 15 and 18 PSIG.
supers05 likes this.
Old 01-06-2018, 01:37 PM   #6
Guest
Here's some pictures of below the boiler, side of it, and top of it. If someone can please tell me which thing would increase the PSI. Another question, should the PSI still show 10 even when it's not running?
Electric boiler...is my pressure too low?-img_20180106_142635607_1515267415959.jpg   Electric boiler...is my pressure too low?-img_20180106_142644463_1515267427910.jpg   Electric boiler...is my pressure too low?-img_20180106_142650787_1515267442650.jpg
Old 01-06-2018, 01:38 PM   #7
Guest
Should that be done when it's running or when it's sitting idle?
Old 01-06-2018, 02:38 PM   #8
Guest
I'm looking at the nut and screw. The screw is already turned all the way clockwise and when I try to loosen the nut the screw turns as well. It looks like the screw and nut are one piece?
Old 01-06-2018, 04:53 PM   #9
Guest
Can anyone please help with this?
Old 01-06-2018, 08:18 PM   #10
An old Tradesmen
Put screw driver in screw slot, use it as a hold back, while you loosen the nut.
Old 01-06-2018, 08:38 PM   #11
Guest
What about that lever on the side? Should that be moved? It says Fast Fill. Is that in the proper position?
Thanks for any help guys.
Old 01-06-2018, 09:47 PM   #12
An old Tradesmen
Can't tell from pic.
In the fast fill position. It simply pushes the valve open, until it moved back to the auto position.
Old 01-07-2018, 06:47 AM   #13
Rewards Points: 2,076
Hey, dumb question from a non-HVAC guy here: Is increasing the pressure going to help the circulator increase flow to the attic?
It seems to me you can think of it as the cirulator sort of creating a differential pressure; suction before and pressure after the pump. It would seem that it's the difference in pressure which moves the water.
Am I missing something?
CaptTom is offline   Reply With Quote
Old 01-07-2018, 07:17 AM   #14
An old Tradesmen
A circulator is not a pump. It can only move water if the water is already there.
The OP's water pressure is low, so the water's column height is low, and not allowing the water to move in the attic rad. Its a very common problem.
The Following User Says Thank You to beenthere For This Useful Post:
CaptTom (01-07-2018)
Old 01-07-2018, 08:04 AM   #15
Guest
Been there, I sent you a private message if you could help me further. Thank you.
Well Problem Pump or Pressure switch? volleybiggs Plumbing 3 12-31-2017 09:34 AM
Suspect Electric boiler causing brownout crankcase Electrical 4 11-06-2012 01:41 AM
Slantfin Galaxy Boiler Pressure Mystery chiefswabjockey HVAC 18 11-15-2011 05:37 PM
Hydronic boiler pressure question. RickInMissouri HVAC 1 01-23-2010 04:57 AM
