EcoBee-3-4-5 Or NEst - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By user_12345a
Old 05-29-2020, 05:01 PM   #1
Rewards Points: 92
EcoBee-3-4-5 or NEst
We just got solar panels and we need to get a smart thermostat
Any ideas?
Beebad is offline   Reply With Quote
Old 05-29-2020, 05:16 PM   #2
user_12345a's Avatar
Rewards Points: 108
Re: EcoBee-3-4-5 or NEst
ecobee! nest has a horrible reputation.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
The Following User Says Thank You to user_12345a For This Useful Post:
Beebad (05-29-2020)
Old 05-29-2020, 06:19 PM   #3
Rewards Points: 92
specifically will either allow adjustment of aprilaire 800, and if there is a power failure can the echobee still control the HVAC manually?
Old 05-29-2020, 06:22 PM   #4
Rewards Points: 108
It draws power from the furnace/air handler transformer with C connected, so if furnace has power from a generator or other source when grid goes down, ecobee should work.
I believe it can control the humidifier using the accessory terminal, would need at least one extra wire to the stat.
Read specs and literature before buying to be sure it does everything you want.
Beebad likes this.
