An Easy Question - HVAC - DIY Chatroom Home Improvement Forum
Old 04-09-2012, 06:55 PM   #1
Rewards Points: 121
An easy Question
I took the Inducer pan off my furnace,today it was broken, and i have a replacement for it..
This Pan is made of plastic... i took the screws out and there is Caulking that was holding the two pieces together, i split the caulking and separated the two pieces. One piece stays with the furnace.
The caulking is grey in color .. My question is , do they use special caulking for too join them back together..
I would not think heat is an issue as these pieces are plastic.. The piece that is still on the furnace, has the secondary heat exchanger tubes coming through it... so the condensation from the gas would go into the plastic pan and then drain out too the condensation trap and to the pump.
here is a picture
rick31797 is offline   Reply With Quote
Old 04-09-2012, 07:17 PM   #2
Rewards Points: 6,652
It may be the same as RTV for autos and such, but wait until one of the hvac guys show up and answer.
Old 04-09-2012, 07:24 PM   #3
An old Tradesmen
Rewards Points: 7,862
Any high temp caulk is fine, that area doesn't get real hot. myself, I prefer RTV.
Old 04-09-2012, 07:39 PM   #4
Rewards Points: 582
rtv all the way
Old 04-09-2012, 08:14 PM   #5
Rewards Points: 121
caulking
Thanks for the help i will get RTV
Help please easy question Tamguildshamroc Electrical 5 04-25-2011 09:03 AM
truck electrical question itin1200 Electrical 8 03-31-2011 01:58 PM
An easy question for your guys which is hard for me~ pls help~~ keifoo Electrical 9 10-05-2009 10:58 AM
easy question - PVC conduit connection to main panel tpagel Electrical 14 07-17-2009 06:50 PM
Easy Drywall Question hohandy Building & Construction 10 12-16-2005 12:18 AM
