EAC Terminal Voltage Trane S9v2 - HVAC - DIY Chatroom Home Improvement Forum
Old 12-30-2018, 12:55 AM   #1
Rewards Points: 2
EAC terminal voltage Trane S9v2
I have a new Trane S9V2 and am installing a Aprilaire 5000 electronic air cleaner. The S9V2 manual says the EAC terminal on the control board is 120V max 1Amp. When I turn on the fan I do not meassure 120V across the two EAC tabs. Tabes are numbered E8 and E10 located at the top left.
Is one a neutral tab a and other line, if so which is line.
Should I be measuring 120V AC when the fan is running?
Looking to hook up the outlet for the Aprilaire 5000.
dstock66 is offline   Reply With Quote
Old 12-30-2018, 12:30 PM   #2
user_12345a's Avatar
Rewards Points: 108
Re: EAC terminal voltage Trane S9v2
There should be 120v between eac terminals with the blower on.
Yes one would be neutral, one would be hot.
The installer should have left all the literature with you -> the install manual should have info on hooking up an eac.
Be sure to mark the plug you installed "air cleaner only" because if someone plugs in something that draws too much current, the board could be damaged.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 08-23-2020, 04:19 PM   #3
Any luck on this EAC. I have a new trane s9v2 Wanting to connect a relay for a booster fan. I'm not getting any voltage on the eac terminals.
My relay can take 24v or 120v as a trigger. I thought the eac was the easy spot but I'm not getting power whilE the fan is running.
Thechevyman is offline   Reply With Quote
Old 08-23-2020, 07:02 PM   #4
Rewards Points: 918
Apparently the HUM and EAC terminals are dry contacts. You can verify this with an ohm meter. Switch should be closed when fan running and open when fan is off. You can provide a jumper from L1 connection to one side of the switch and connect your EAC. Common from EAC back to common on furnace.
57TinkerMan is offline   Reply With Quote
Old 08-23-2020, 07:24 PM   #5
Rewards Points: 108
don't waste your time/money with booster fans.
Old 08-23-2020, 07:36 PM   #6
Rewards Points: 918
A bit more helpful, maybe.
Old 08-23-2020, 07:50 PM   #7
Thank you! I'll take a look and test this out.
The booster fan was already installed when we bought the house. It's on a manual switch in the bonus room above the garage. It does a good job so I plan to run a relay of the furnace so it can only run while the system is on.
Tags
trane s9v2 eac hvac
Automatic Voltage Regulator/Stabilizers ThePeck Electrical 1 06-08-2014 09:33 PM
voltage on earth wire Spikeyboy Electrical 13 10-15-2010 11:03 AM
Voltage in Metal Roof and Gutters TITAN2390 Electrical 4 10-07-2010 07:44 PM
"G" terminal on Tstats javan HVAC 8 02-08-2009 02:16 PM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 07:15 PM
