Ducted Mini Split Heat Pump Air Handler Orientation Question - HVAC - DIY Chatroom Home Improvement Forum
Old 09-16-2020, 07:57 PM   #1
Rewards Points: 2
ducted mini split heat pump air handler orientation question
I know there are DIY ductless heat pumps available, but I'm looking to retrofit a ducted system into the space designed for a downflow furnace in a manufactured home. I haven't seen any advertised DIY systems that are designed to mount the air handler in a downflow orientation. Even the MRCOOL Universal system, advertised as allowing "multi-positional installation", specifically allows only horizontal and upflow orientation.
I'd rather avoid kludging together an awkward 90 or 180 degree bend in the ductwork. So is there some compelling reason an air handler MUST be oriented as advertised? If, for example, I mounted a "horizontal only" air handler pointing downward, would anything bad happen in the short or long term?
Thanks in advance,
Rob
rccapps is offline   Reply With Quote
Old 09-16-2020, 08:15 PM   #2
Rewards Points: 716
Re: ducted mini split heat pump air handler orientation question
You’d be unable to operate the unit in cooling, as the condensate would have no collection pan and would just leak out everywhere.
roughneck is online now   Reply With Quote
Old 09-17-2020, 04:16 PM   #3
An old Tradesmen
Rewards Points: 54
You need a unit made for downflow.
Tags
air handler , heat pump
