Dual Zone Question - HVAC - DIY Chatroom Home Improvement Forum
Old 09-06-2020, 04:37 PM   #1
Rewards Points: 4
Dual Zone Question
We have one AC compressor unit that cools a Kitchen and a playroom (2 zones). For some reason, the AC in the kitchen does not kick in from 11 am to 5 pm. The Kitchen gets really hot. We have had a pro look at it. He changed the thermostats, cleaned the outside filters, fixed some kinks and changed the evaporator coil.
The issue still exists. We have turned off the thermostat in the playroom to see if it was drawing too much energy, but that did not seem to work.
Then, once evening hits, the Air Handler kicks in and cool air comes to the kitchen.
Any thoughts would be welcome.
pcampo is offline   Reply With Quote
Old 09-06-2020, 07:20 PM   #2
Rewards Points: 764
Re: Dual Zone Question
This is a minisplit with 2 heads?
What is the make and model?
roughneck is online now   Reply With Quote
Old 09-07-2020, 06:45 AM   #3
Rewards Points: 4
This is central AC with an air handler in the attic and it controls two zones.
Old 09-07-2020, 08:21 AM   #4
Rewards Points: 764
Unfortunately we will need much more information to even begin to diagnose the problem.
What is the make and model of the unit?
What zoning panel is being used?
What thermostat is being used?
Is the zone damper opening during the day? Is it being powered?
Old 09-07-2020, 12:55 PM   #5
An old Tradesmen
Rewards Points: 124
Is the thermostat a set back thermostat, and going into set back during the day? That would be factory default.
Does the thermostat display say it is cooling.
