Dual Tank Oil Setup - HVAC - DIY Chatroom Home Improvement Forum
Like Tree5Likes
Old 03-06-2020, 04:35 PM   #1
I have two 275 oil tanks that are connected via a T in the lines going to the furnace. One is on its side (horizontal 275) and one is standing up. The horizontal one has over flowed before. When filling up I thought they were connected in the sense that they would self level and even out but the oil company filled 1 (275H) and the other one (275V) is still at 1/4 full.
My question is this...
Will they eventually even out?
Is there any danger of the horizontal tank overflowing if the vertical is filled second or did the oil company just make a mistake that one time?
And finally, can I run it as is or is there a danger in completely emptying an oil tank?
I wasn't sure if there was debris or odd things that happen when an oil tank is sucked completely dry.
Thank you for your help and advice!
Tpalmer is offline   Reply With Quote
Old 03-06-2020, 05:17 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 130
Re: Dual tank oil setup
If there is an opening in the lower tank below the fill level of the other tank it could overflow as the oil balances its level between the two tanks. If all the fills and overflows are at the same level there should be no overflowing unless there is a leak.
Bondo likes this.
Old 03-06-2020, 05:58 PM   #3
Rewards Points: 424
Maybe this chart will help clear the mystery.
http://www.barrier.com/oil-tank-chart/
Old 03-06-2020, 06:52 PM   #4
I know the sizes of the tanks they're both 275's one is one its side. Finding out if they're at different levels will be more difficult since they're about 20 feet apart and with a wall in between the two. I'll try to find that out.
Old 03-06-2020, 06:53 PM   #5
So if the connection between the tanks is lower than both tanks, they may still level out?
Old 03-06-2020, 07:29 PM   #6
Super Moderator
joed's Avatar
Rewards Points: 130
Unless there are check valves in the lines then oil between the tanks will level out. A check valve would allow oil to flow out but not back in.
You would need the oil to level out otherwise one tank could run dry and furnace would suck air from that tank unless you have manual control valves to switch between tanks.
Bondo likes this.
Old 03-06-2020, 07:56 PM   #7
So definitely do not run it with one empty and the other full? That's good to know cause that's exactly what I was planning on doing.
If they don't level out, then I'll get the one filled.
Old 03-06-2020, 08:42 PM   #8
Rewards Points: 764
Are these definitely connected together?
I’ve never seen connected tanks differing in layout, and so far apart. What’s the piping look like?
roughneck is online now   Reply With Quote
Old 03-06-2020, 08:45 PM   #9
Rewards Points: 3,580
I would suspect that the T connection under the oil tanks is partly clogged so oil does not equalize between the tanks easily.
I would expect that with a T connection at least 3/4 inch inside diameter and below the levels of both tank bottoms and also no check valves you would not have a problem of one tank emptying out first and then the oil burner sucking air. Each tank should have its own full indicator whistle.
But when the delivery guy comes and starts to fill one tank, the T connection will not equalize fast enough to fill both tanks from one fill point before the whistle indicates full. And it will not be possible to guess when to move the nozzle to the other tank's fill point because additional equalizing will occur while he moves the nozzle.So long ast the pipework is properly sealed (pipe dope, Teflon tape or whatever) and the two fill points are above the tops of both tanks, you should not get an overflow from the second tank before the first is full.
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
Old 03-06-2020, 08:49 PM   #10
Super Moderator
joed's Avatar
Rewards Points: 130
It should not be possible to run one tank empty if they are piped together. It's all speculation unless we know exactly what you have.
Old 03-06-2020, 09:51 PM   #11
This is how far apart the tanks are.
Old 03-06-2020, 09:52 PM   #12
This is the T connection and tap into the vertical oil tank
Old 03-06-2020, 09:52 PM   #13
And finally the tap into the horizontal oil tank.Dual tank oil setup-20200306_223936_1583553159915.jpg
Old 03-06-2020, 09:53 PM   #14
Rewards Points: 764
Is there a line passing to the bottom of each tank to equalize the fuel level?
Old 03-07-2020, 08:20 AM   #15
Just the skinny line that connects into the T.
