Drain Line | HVAC | Cleaning - HVAC - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By surferdude2
  • 2 Post By clocert
  • 1 Post By jjrbus
Old 07-15-2020, 10:38 PM   #1
Rewards Points: 4
Hey all,
I have an HVAC and I'm 3 years into use and it's probably time (over time) that I clean the drain line.
There's an image attached.
I'm wondering about best practice to clean this drain line?
The opening ("1" in the photo) is where I'd expect to lightly blow and put cleaning solution in but, how in the heck do I reach the elbow ("2" in the photo)??? It's on a 90 degree from the open topped pipe.
Tips and recommendations please! Thanks. ))
P.S. That "Open Top" isn't capped off ... should it be???
vitamin is offline   Reply With Quote
Old 07-16-2020, 08:51 AM   #2
surferdude2's Avatar
Rewards Points: 896
Re: Drain Line | HVAC | Cleaning
My system has been running more than 16 years without a problem with drain pluggage so I suppose it's dependant on some factors that vary from one installation to the next.
That aside and to address your concerns, I would recommend removing the ell from the dain overflow and replacing it with a tee. Perhaps then adding a length of pvc and fittings to the tee as a riser to make access for a funnel insertion when the time came to flush the drain with some disenfectant. You would then plug the bottom of the tee temporarily and pour the stuff into the riser so it would flow back into the drain pan under the evaporator coils and on out through the connected drain.
As mentioned, it may not actually be necessary but chicken soup is always good.
I can't tell clearly from the picture but I hope I see an overflow pan with a switch mechanism that shuts down the system when the coil drain pan overflows.
vitamin likes this.
Ah, but I was so much older then...I'm younger than that now
surferdude2 is offline   Reply With Quote
Old 07-16-2020, 02:20 PM   #3
Rewards Points: 344
Replace the 90 degree elbow above the P-trap with a T. or if you are lazy like me, simply drill a hole on the top of the 90 degree elbow, tape it after the cleaning.
Chris130 and vitamin like this.
clocert is offline   Reply With Quote
Old 07-16-2020, 09:56 PM   #4
Rewards Points: 1,202
I did not know or think about AC much till I moved to Florida. My first house the AC system was put in by an AC contractor who owned the house and I never had any issues. AC was over 20 years old when I sold house and still working.
The second house 25 years old was a spec built house and the AC system showed it, crappy job, installed by lowest bidder. Anyway one day my wife said there was water dripping from the light in the closet, directly under the air handler in the attic. We have a coal fired plant not hydro so I knew electric was not the problem.
Long story short, I learned about vacuuming out the drain line a couple times a year to keep it clean. Bunch of You tube videos about it.
vitamin likes this.
jjrbus is offline   Reply With Quote
Old 07-21-2020, 08:34 AM   #5
Rewards Points: 4
Thanks all for the suggestions and insight. Cheers.
Tags
hvac
