Downflow To Upflow - HVAC - DIY Chatroom Home Improvement Forum
Old 04-22-2020, 01:28 PM   #1
Downflow to upflow
I have an air handler that had the option to be installed as an upflow or downflow. It was installed a few years back as a downflow and I would like to change it to an upflow.
Tapgar is offline   Reply With Quote
Old 04-22-2020, 02:48 PM   #2
Rewards Points: 748
Re: Downflow to upflow
Are you going to reverse your duct work?
roughneck is offline   Reply With Quote
Old 04-22-2020, 04:43 PM   #3
I am planning to running new ductwork. The old ductwork is falling apart which means I am just air conditioning my crawl space.
Old 04-22-2020, 08:23 PM   #4
sktn77a's Avatar
Rewards Points: 1,028
Great! So what's your question?
sktn77a is offline   Reply With Quote
Old 04-22-2020, 10:47 PM   #5
user_12345a's Avatar
Rewards Points: 90
the manufacturer should have specific instructions in the install manual for converting - probably to do with drain lines/pan and coil orientation.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
