Does Not Blow Warm Or Hot Air At All - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Old 02-03-2020, 11:22 PM   #31
Rewards Points: 50
Re: Does not blow warm or hot air at all
lol I got it! I will check tomorrow morning and will post it!
Thank you again!
stayorlando is offline   Reply With Quote
Old 02-04-2020, 08:23 AM   #32
Rewards Points: 50
I checked Y and C get 24v.
What should I check next?
Thank you!
Old 02-04-2020, 08:25 AM   #33
Rewards Points: 724
Was that at the air handler or outdoor unit?
If at the air handler check outside for line and low voltage.
roughneck is offline   Reply With Quote
Old 02-04-2020, 08:29 AM   #34
Rewards Points: 50
checked both and all get 24v, but still does not run the outside unit while still blowing strong air.
Old 02-04-2020, 08:37 AM   #35
Rewards Points: 724
Is there line voltage to the outdoor unit?
Is there power to the contactor coil?
Is the contactor pulled in?
Old 02-04-2020, 09:00 PM   #36
Rewards Points: 50
everything works fine.
240v, 24v, contactor pulled in!
Old 02-04-2020, 09:14 PM   #37
Rewards Points: 724
So the contactor is pulled out in but nothing in the outdoor unit is operating?
Check load voltage. If ok test the capacitor. If that’s ok ohm out the compressor.
None of this is causing your lack of auxiliary heat, that’s going to be a separate problem.
Old 02-04-2020, 09:16 PM   #38
Rewards Points: 50
Ok! I will check that tomorrow and will update you again! Thanks for your help!
Old 02-04-2020, 09:31 PM   #39
Rewards Points: 50
One more question!
I remember I didnt change one of the capacitor because I purchased the dual capacitor with the same spec for the cylinder one in the picture.
Can I just use one dual capacitor insteda two single capacitor I currently have?
Am I right connecting two brown wires on COM and Fan & yellow to Herm and Red to Com?
Thank you again!
Old 02-04-2020, 09:34 PM   #40
Rewards Points: 724
You can use either a duel or single.
Test them with your meter to see if they are good or not.
The capacitor rating has to match the requirements of the motor it’s serving.
Old 02-04-2020, 09:40 PM   #41
user_12345a's Avatar
Rewards Points: 48
See if the output of the contactor is 240v -> you can have a contactor that pulls in but has cooked contacts. it's unlikely though.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is offline   Reply With Quote
Old 02-04-2020, 09:42 PM   #42
Rewards Points: 50
Dear roughneck!
I have a brand new dual capacitor that has same as the rusty one I currently have on unit.
I am not sure if the idea I am going to wire on the new one is correct.
currently two brown wires go into on the small single capacitor and one yellow and one red line go into on the big rusty capacitor on the right side.
Am I do ing right two brown wires go on COM and Fan, Yellow to Herm, and Red to Com if I use a brand new dual capacitor instead two single capacitor ?
Does not blow warm or hot air at all-capacitor.jpg   Does not blow warm or hot air at all-dual.jpg
Old 02-04-2020, 09:44 PM   #43
Rewards Points: 724
Test the electrical system first. And the existing capacitor.
Don’t worry about changing parts till you figure out what’s going on.
Old 02-05-2020, 08:05 AM   #44
Rewards Points: 50
I checked all parts again and contactor does not pull in when heat is on.
I get 24v on C and Y C and R on the defrost board.
Old 02-05-2020, 08:07 AM   #45
Rewards Points: 50
here is the compressor in my unit!
Does not blow warm or hot air at all-compressor.jpg   Does not blow warm or hot air at all-c2.jpg
