Does Anyone Make A Really Sturdy, Durable Heat Register? - HVAC - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Nealtw
  • 1 Post By SPS-1
Old 02-15-2020, 11:11 AM   #1
Rewards Points: 503
Does anyone make a really sturdy, durable heat register?
The heat registers I buy at the home improvement stores seem to break within a year or so. Eventually the slider to open and close the fins or the fins themselves break.
Are there any brands of heat register that are really durable and hold up to repeated openings and closings? If so, what do you recommend and where can I buy it? Thanks in advance for your help!
Studly is offline   Reply With Quote
Old 02-15-2020, 11:16 AM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 678
Re: Does anyone make a really sturdy, durable heat register?
I know they are made.....in my former home I had a very sturdy brass curved register in the middle of a wide entry into a sunroom. It was walked on allthe time...it was expensive as registers go....maybe &30 alotn of years ago.
Back then, HD caried it...maybe not anymore...but I'm sure the internet has one.
MTN REMODEL LLC is online now   Reply With Quote
Old 02-15-2020, 11:19 AM   #3
Rewards Points: 11,460
Thats a good question. I will be keeping my eye on this thread.
I rarely change the opening on mine, but I do find keeping a nice finish a challenge. Probably got mine at HD --- the ones with gloss black enamel are holding up fine. But the ones with the yellow-gold metal plating already rusting after 5 years.
SPS-1 is online now   Reply With Quote
Old 02-15-2020, 11:20 AM   #4
retired framer
Rewards Points: 706
You might try one with a more solid top, solid brass or SS
https://www.google.ca/search?q=brass...w=1093&bih=502
MTN REMODEL LLC likes this.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 02-15-2020, 12:03 PM   #5
Yeah, look for the words "solid". Below is the one I got -- plating must be a few microns thick - does not last.
Nealtw likes this.
Old 02-15-2020, 12:08 PM   #6
user_12345a's Avatar
Rewards Points: 68
some fancy heat registers can be very restrictive to flow.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 02-15-2020, 12:25 PM   #7
Rewards Points: 503
Thanks for the tips, everyone. I guess I should have mentioned that the one that is really causing me problems because we open and close it a lot is a larger wall register with lots of fins. Seems to be more fragile than the smaller floor registers.
Old 02-15-2020, 12:27 PM   #8
Rewards Points: 68
why not just leave it open/adjust it to the room is comfortable?
closing vents in unused rooms doesn't really save energy and can create problems.
Old 02-15-2020, 02:28 PM   #9
Rewards Points: 503
That's the problem is I can't adjust it to get the temp in the room correct. The slider breaks and the fins quit rotating.
Old 02-15-2020, 05:10 PM   #10
Rewards Points: 68
See if there's a damper in the pipe feeding the register - it's usually near the register or take-off from the trunk line.
It's best to adjust that damper, if it's there than to do the same with the one on the register.
Old 02-15-2020, 09:23 PM   #11
An old Tradesmen
Rewards Points: 98
Hart&Cooley 411 floor register.
