Do Capacitors Just Wear Out Or Is There Something Behind Them Failing? - HVAC - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 1 Post By SeniorSitizen
  • 1 Post By user_12345a
  • 1 Post By yuri
  • 2 Post By kevinande
Old 06-11-2020, 11:53 AM   #1
Mike Milam's Avatar
Rewards Points: 68
Do capacitors just wear out or is there something behind them failing?
About 10 days ago my wife asked why the house was hotter than normal. I went down and checked the furnace and found it was frozen over and the blower was running slow. I checked the blower motor capacitor and got no reading at all. I managed to locate one through a friend of a friend and replaced it. Everything has been fine since. Is there something looming I should be watching for? Thanks
Thank a police officer for being the one who runs 'TO' a report of shots fired, while everyone else runs 'AWAY'
Mike Milam is offline   Reply With Quote
Old 06-11-2020, 12:15 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 196
Re: Do capacitors just wear out or is there something behind them failing?
They rarely fail on furnace blower motors ( outdoor unit ones go often ).
IMO it is because they are made as cheap as heck in China or Malaysia etc and don't last like the old school ones.
Probably just a dud and nothing to worry about.
The Following User Says Thank You to yuri For This Useful Post:
Mike Milam (06-11-2020)
Old 06-11-2020, 12:47 PM   #3
Rewards Points: 320
Outdoor they don't wear out so often but mice or lizards can be a problem when mounted with terminals UP.
Mike Milam likes this.
Old 06-11-2020, 01:07 PM   #4
Rewards Points: 166
My experience is with electrolytic caps on printed circuit boards, probably similar. Most failures I replaced were related to heat, many thousand replaced. Most were adjacent to or above a heat source.
But Yuri's comment "because they are made as cheap as heck in China or Malaysia" has a lot to do with it.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
The Following User Says Thank You to Bud9051 For This Useful Post:
Old 06-11-2020, 01:15 PM   #5
user_12345a's Avatar
Rewards Points: 60
You can buy made in usa caps - more $$ though.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 06-11-2020, 01:23 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 196
Lizards??
We have no lizards or snakes or allygators where I am.
I get mice being zapped on top of them and contactors when they are mounted flat.
Old 06-12-2020, 03:31 PM   #7
What, me worry?
cheeno's Avatar
Rewards Points: 168
What brands are USA made? Do they seem to be better and last longer?
cheeno is offline   Reply With Quote
Old 06-12-2020, 03:46 PM   #8
Mike Milam's Avatar
Rewards Points: 68
The one that failed was GE and assembled in Mexico. The one I replaced it with was the same. To the best my knowledge it was 18 years old.
Old 06-12-2020, 04:37 PM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 196
18 years is very good. I see them last less than 10 on outdoor AC units.
The Mexico stuff is pretty good as Honeywell and Lennox have been building parts there for 30+ years. The Asian stuff not so great.
Old 06-12-2020, 04:48 PM   #10
Rewards Points: 136
Amrad are the only ones I purchase. They are more expensive, but they last longer than the cheap Chinese caps. The last one I changed was about 5 years ago on one of my rentals and I suspect it was damaged during a storm. This is a heat pump so it sees continuous use all year round and it was 10 years old I believe, maybe older. I always keep spares because when they do go it is always on a Holiday during a 3 day weekend at midnight!
Mike Milam and cheeno like this.
kevinande is offline   Reply With Quote
