Contactor Replace - HVAC - DIY Chatroom Home Improvement Forum
Old 06-30-2020, 10:50 AM   #1
Rewards Points: 300
Contactor replace
I've had to replace my contactor ,on package unit heat pump every few years it seems, an wanted to know what to look at.
It works when contactor is pressed so I need to see if it's getting the 24 volts an stat signal also.
If it's getting the 24v
would changing to a 50 a instead of 30a help ?
Any additional info on what else to look at is appreciated.
This is what's on it now.
hidden 1 is offline   Reply With Quote
Old 06-30-2020, 11:02 AM   #2
Rewards Points: 716
Re: Contactor replace
What is the problem that’s requiring replacement?
Coil issues? Arching the contacts?
roughneck is online now   Reply With Quote
Old 06-30-2020, 02:33 PM   #3
Rewards Points: 300
Seems the contactor isnt engaging again on next season start up ..after working fine all fall an winter An didnt need ac much till lately..
I'm gonna recheck stat an by pass it to see if that is factoring it .maybe a wire issue,
I will test it an look for the 24v at contactor also .
But it's only running with contactor "in " till I can test/repair it. An I'll be running new stat wire too .
If it's bad should I stay with a 30a?
An are those cheap 10$ honeywell ones like I've used pretty crappy ones[maybe factoring issues].
Any additional info is appreciated.
Old 06-30-2020, 05:15 PM   #4
surferdude2's Avatar
Rewards Points: 896
It's not a good idea to hold a contactor in manually to run a refrigeration system. If it's low on refrigerant, a low pressure switch will be keeping it from coming on to prevent short cycling but also prevents sucking air into the system, especially if it has a low side leak.
Honeywell is pretty much first cabin stuff so that shouldn't be an issue. Everything come from China it seems.
Check for 24volts ac on the control wire (R and C) running from your thermostat to the defrost board terminals on the condenser unit. If it's there, measure it at the contactor coil. If it's missing there, it'll take access to the schematic for that unit to follow the control wiring path to see why it's being blocked.
A failed contactor would be the easiest thing to diagnose but you may not be so lucky. Post back with what you find and also give the make and model# and a picture of the schematic that is inside the unit electrical cover.
Ah, but I was so much older then...I'm younger than that now
surferdude2 is offline   Reply With Quote
