Connection Question On Trane XR90 - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-25-2020, 03:04 PM   #16
Tried the unit yesterday; getting there blinking lights; I hear the unit spinning up but no air is coming through the vents.. I think the Trane manual mentions possible intake clog? I had a guy come and clean out the drain cuz the AC was leaking but now this issue. Any ideas?
Lord Do is offline   Reply With Quote
Old 08-26-2020, 06:52 AM   #17
*Three
Old 08-27-2020, 11:58 AM   #18
Sorry meant to say three*
Old 08-27-2020, 01:57 PM   #19
Rewards Points: 30
Re: Connection Question on Trane XR90
https://www.bing.com/search?q=xr90+3...16&FORM=CHROMN
diyorpay is offline   Reply With Quote
Old 08-27-2020, 02:03 PM   #20
surferdude2's Avatar
Rewards Points: 908
shut off the power and it should reset and work properly. The code was generated when you ran the unit with the inducer unplugged or inoperative.
Ah, but I was so much older then...I'm younger than that now
surferdude2 is online now   Reply With Quote
Old 08-27-2020, 02:51 PM   #21
Just tried; still same issue.
Maybe I didn’t put enough RTV silicone ?
Old 08-27-2020, 04:19 PM   #22
Just checked the drain from the inducer, poured some water in and it drained fine.
I’m wondering if it has to do with that screw? Because that connects to the pressure switch. The guy who cleared the clog took out that screw; not sure why. I put it back but not sure if that has to be like completely sealed around the threads of the screw?
Old 08-27-2020, 05:57 PM   #23
Rewards Points: 83
That is the wrong gas valve for this furnace. It should have a vent connection that that hose connects to. It references the burner box to set gas pressure.
Sent from my iPad using Tapatalk
Ebierley is offline   Reply With Quote
Old 08-27-2020, 06:43 PM   #24
Yikes, I figured. Is there any way to make it work again? I worked with that gas valve before.
