Condensate Water In Pan, But Line Is Clear - HVAC - DIY Chatroom Home Improvement Forum
Old 06-11-2020, 06:26 PM   #1
Rewards Points: 34
Condensate water in pan, but line is clear
There is about an inch of water in the drain pan. I ensured that the condensate line was clear. Could the water be dripping out of an unplugged secondary hole? See pic.
Sent from my SM-N960U using Tapatalk
KurtP is offline   Reply With Quote
Old 06-11-2020, 07:48 PM   #2
surferdude2's Avatar
Rewards Points: 902
Re: Condensate water in pan, but line is clear
If water comes out of that secondary drain, your main drain is plugged. It can happen at the coil drain pan at the opening going out to the trap, before it gets to the trap. For a permanent tattletail device, set a small bowl directly under the secondary drain so you can know if the secondary is flowing.
Hopefully the overflow switch is wired to protect from damaging overflow.
Ah, but I was so much older then...I'm younger than that now
surferdude2 is online now   Reply With Quote
