Condensate Line For Basement Minisplit - HVAC - DIY Chatroom Home Improvement Forum
Old 04-23-2020, 05:02 PM   #1
Rewards Points: 172
condensate line for basement minisplit
I am installing a 2 zone - 1 upstairs and 1 downstairs. The outdoor unit IS below where the basement minisplit will sit on the wall. But the only place I can run the lineset, electrical and condensate lines in and out of the building is about 12 inches above where the basement minisplit will sit on the wall.
will the condensate line work like this or is there something special that needs to be donw in a case like this?
bobmane is offline   Reply With Quote
Old 04-23-2020, 06:48 PM   #2
Rewards Points: 758
Re: condensate line for basement minisplit
Basic wall mount indoor units do not have a pump.
You’ll need to gravity feed the condensate our or install a pump, such as the mini orange pumps.
roughneck is online now   Reply With Quote
Old 04-23-2020, 08:45 PM   #3
Rewards Points: 172
I should have said what I am wondering is if since outdoor is below it would still work (like if you had a rain catchment system off a roof the pipes in the run could fall below the entry to the tank since the source is higher then the tank)
Old 04-23-2020, 09:02 PM   #4
Rewards Points: 758
No, the drain doesn’t work like that.
Placement of the outdoor unit doesn’t matter much.
The condensate drains off the coil into an open pan. Then gravity drains out of the pan and down the drain pipe.
If you want to go up, you need an aftermarket pump.
You'd make a trap in the pipe and back water up into the indoor head.
The Following User Says Thank You to roughneck For This Useful Post:
bobmane (04-23-2020)
Old 04-23-2020, 09:09 PM   #5
Rewards Points: 758
What brand/model equipment is going to be installed?
Old 04-23-2020, 09:41 PM   #6
Rewards Points: 172
Model: https://www.ebay.com/itm/29215005735...m=292150057351
The 12 is going in the basement
Old 04-23-2020, 10:01 PM   #7
Rewards Points: 758
Yup, you’ll need a pump or run the drain down from the head.
Gravity drain cannot go uphill from the head.
