Condensate Leak At Pan/plastic Interface - HVAC - DIY Chatroom Home Improvement Forum
Old 08-13-2020, 04:54 AM   #1
Rewards Points: 14
Condensate leak at pan/plastic interface
Hi,
I have a Trane 2 1/2 ton unit.
I have a condensate leak right at the point the metal drip pan interfaces with a plastic transition piece to the condensate drain. It is in the corner. It does not appear to be rusted, but the gasket or sealant has failed in that corner (I think gasket).
I can't figure out how to get the plastic piece out in order to remove the entre pan assembly. Any thoughts.
Any other ideas to stop the leak.
Thank you
Condensate leak at pan/plastic interface-ac-close-up-3.jpg
Yoshi8209 is offline   Reply With Quote
Old 08-13-2020, 06:34 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 162
Re: Condensate leak at pan/plastic interface
Dry it, clean it with steel wool and seal the leak with DAP high quality plumbing silicone. Or RTV silicone if you have it.
Do it on a day when it does not run as any water drops may cause the silicone to not cure or stick. Use a hair dryer or heat gun to get rid of the water first.
Old 08-13-2020, 09:02 AM   #3
Rewards Points: 14
I'll try that, thank you for the recommendation. I'll let you know.
Old 08-13-2020, 01:51 PM   #4
Rewards Points: 344
The picture is too dark, can not see anything. the bottom line is, you should not see water anywhere, if you see water, you have a problem.
clocert is offline   Reply With Quote
Old 08-14-2020, 01:32 PM   #5
Rewards Points: 14
I used the silicone and it seems to have resolved the issue. Thank you for the suggestion.
Just curious, there is an absorbent pad below the metal tray and seems to be always damp. It catches small drippings from the bottom of the pan that fall from water condensing under the metal pan. I guess that is the way its suppose to be.
Old 08-14-2020, 01:43 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 162
It probably is insulation to prevent cooling loss.
It should dry up once the leak is stopped.
