Condensate Drain Pan Not Working Properly - HVAC - DIY Chatroom Home Improvement Forum
Old 07-21-2020, 03:22 PM   #1
Condensate Drain Pan not working properly
Hey I have a supco cp804hd about 3 years old but doesn't work go good anymore , any way to clean it?
Any better replacement I can buy for it ?
Bkboy is offline   Reply With Quote
Old 07-21-2020, 03:29 PM   #2
Rewards Points: 918
Re: Condensate Drain Pan not working properly
What are you using this on? This type of pan is costly to operate, any possibility of installing a condensate pump? Much cheaper.
57TinkerMan is online now   Reply With Quote
Old 07-21-2020, 03:36 PM   #3
3 ac units 0.5+0.5+1.5HS not all used at the same time , was originally installed ( not by me )
No drain nearby unfortunately .
And I'm very limited with space I attached a picture . If you have any idea please let me know
Condensate Drain Pan not working properly-15953636334642124552734709613774_1595363641950.jpg
Old 07-21-2020, 03:45 PM   #4
Rewards Points: 918
Is it possible to route 3/8" id plastic tubing from the current pan location to a drain/sink/garden etc., it does not have to be close by.
Old 07-21-2020, 03:57 PM   #5
Looked all over nothing that I can drain it too unless I run some pipes into the house and that's not an option .
Old 07-21-2020, 04:06 PM   #6
Rewards Points: 918
Is the outdoor unit on a balcony? Condo installation?
Old 07-21-2020, 04:09 PM   #7
Yes balcony , no gutter or any drain that I could connect to.
But yes everything is connected outdoors
Old 07-21-2020, 04:20 PM   #8
Rewards Points: 918
Do your neighbors appreciate art? Looking at your picture of the pan, it doesn't look too bad. What's the current problem with it?
Old 07-21-2020, 04:24 PM   #9
Do your neighbors appreciate art?[IMG class=inlineimg]https://www.diychatroom.com/images/smilies/biggrin.png[/IMG] Looking at your picture of the pan, it doesn't look too bad. What's the current problem with it?
Attachment 608057
LOL !!! Well first I'm not sure if it's sufficient for the AC units I have and it's over flowing , gets hot and makes some vape but overflowing
Old 07-21-2020, 04:40 PM   #10
Rewards Points: 918
The Supco pan is rated for 8 gallons a day. Typically used for smaller commercial refrigeration units. I assume it worked ok before. If so, you can purchase a replacement element, probably a lot cheaper than a new unit. Note that the link shows a 230V element, don't know if Supco made a 115V model. Not sure who to buy it through, might have to contact Supco.
https://www.supco.com/web/supco_live...804HD-240.html
Old 07-21-2020, 04:45 PM   #11
Rewards Points: 918
If your not sure your pan ever worked correctly, here's a link to higher capacity pans for A/C units.
https://www.briskheat.com/anti-conde...vaporator-pans
Old 07-21-2020, 04:59 PM   #12
Thank you for the links but as you can see I have a very tight space to work in I wish I could fit in a bigger pan, I have two pipes that I'm draining into that pan I was thinking about double decking them one on top of the other I can rig some kind of Mount and have one drain for each pipe the only thing I'm concerned about is they 120v 1000w 8.3 amps and have only 1 dual outlet you think it would be too much on the electrical side of things? I know the worst that could happen is the breaker would fail or turn off every now and then but I'm really afraid of the wires melting we're getting too hot ,what would be your opinion?
Old 07-21-2020, 06:31 PM   #13
Rewards Points: 918
Originally Posted by Bkboy View Post
...what would be your opinion?
Sounds like you stuck with what you have. You mentioned that when the heater element is on you only see a bit of vapor being generated. I would think the water would have to boil if it was going to work at all. If you have the capability to measure amp draw, I would check the existing element and replace it if defective. You could remove the pan and take it to someone who could measure the amp draw for you.
Old 07-23-2020, 07:24 AM   #14
It would really bother me to have to boil off the condensate from A/C units. I would work really hard to find a way to route a condensate pump tubing somewhere. Way cheaper to power. The heat generated also worsens the efficiency of the A/C units.
EdLank is offline   Reply With Quote
