Coleman Furnace Help - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By roughneck
Old 01-08-2020, 08:51 AM   #1
Coleman furnace help
I need help with my 3 yr old Coleman 80,000 btu furnace. Iím putting on a new circuit board . Anyone familiar with this universal replacement board ??? Iím totally lost !!! Board clicking and nothing starting induced draft motor !!
mikeyowens43 is offline   Reply With Quote
Old 01-08-2020, 11:13 AM   #2
user_12345a's Avatar
Rewards Points: 60
Re: Coleman furnace help
It should wire the same way or have specific instruction on how to retrofit.
3 year old unit should be covered by parts warranty - should have called someone out.
I am not in the business of any trade I give advice on. I have non-professional hvac experience + good knowledge of theory. Attempt repairs at your own risk. Never jump out safeties - especially pressure switches - on a furnace for testing with fuel supply on; use a meter. Do not troubleshoot with live line voltage present unless there's no alternative.
user_12345a is online now   Reply With Quote
Old 01-08-2020, 11:54 AM   #3
Rewards Points: 732
Shouldn’t need a retrofit board for a 3 year old unit either. OEM should have been used.
What problem are you trying to solve by replacing the board?
cheeno likes this.
roughneck is offline   Reply With Quote
Old 01-09-2020, 12:45 PM   #4
Rewards Points: 732
OP, did you figure out your problem?
Old 02-04-2020, 04:19 AM   #5
Originally Posted by roughneck View Post
Shouldnít need a retrofit board for a 3 year old unit either. OEM should have been used.
Unit wonít start up.
Old 02-04-2020, 06:12 AM   #6
Rewards Points: 732
Is the problem fixed?
