Code For Dryer Vent? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Old 09-01-2020, 11:44 PM   #16
Hammered Thumb
Rewards Points: 76
Re: Code for dryer vent?
The flexible duct can only be used as a transition from the dryer to the permanent exhaust duct and cannot be longer than 8'. The remainder must be rigid metal duct. Taped joints are not required, just one of the acceptable methods of joining ducts.
One end of round sheetmetal is pre-crimped, you should not need to buy the crimper. It also comes in 5' lengths. I would use 'U' brackets attached to the concrete wall and keep it rigid all the way to the dryer.
3onthetree is offline   Reply With Quote
Old 09-03-2020, 03:17 PM   #17
Rewards Points: 1,284
Can clamps be used to join sections instead of tape?
Ultrarunner2017 is offline   Reply With Quote
Old 09-03-2020, 03:47 PM   #18
Rewards Points: 686
Clamps work fine for flex duct, but aren't very effective for the 'hard pipe'. I recommend just buying the aluminum tape. I you're anything like me, you'll find plenty of uses for the rest of the roll, once you see how well it works. You may never use duct tape again.
HotRodx10 is offline   Reply With Quote
Old 09-03-2020, 08:11 PM   #19
I purchased the Nashua Premium foil tape which meets UL 181A-P & B-FX. It was expensive, but is a rather large roll, 2.5in wide.
I want to hold off using the tape until I have finalized the install, as I don't want to be wasting tape. I temporarily placed clamps on the hard pipe at the joints. It seems to be holding, but I will use the tape once I have the permanent install done. I plan to replace all of the flex-pipe with hard pipe.
Tags
dryer vent
