Code 61 And 10 Rudd - HVAC - DIY Chatroom Home Improvement Forum
Old 02-10-2020, 10:18 AM   #1
Rewards Points: 2
code 61 and 10 rudd
hvac guy says furnance btu too large for house How do I increase air flow in house to stop 61 and 10 codes new rudd furnance ?Or what can I do thanks Brand new unit
CHEY65 is offline   Reply With Quote
Old 02-10-2020, 10:44 AM   #2
Rewards Points: 738
Re: code 61 and 10 rudd
Is the 61 for a blower fault? And the 10 a lockout?
Have them remove the unit and install the correct size if the unit is brand new.
Did you buy this unit yourself and have it installed?
What are the furnace readings from the commissioning report?
roughneck is online now   Reply With Quote
Old 02-10-2020, 10:53 AM   #3
surferdude2's Avatar
Rewards Points: 908
Probably never be right unless you upsize all ducts. Even then the temperature control may be less than desirable.
I assume the HVAC tech has set the fan speed as high as possible and checked the register dampers and any duct dampers for full opening.
You should consult with the manufacturer for any relief they can offer as regulator settings or to burner configuration by plugging off some. It's never going to be right but if you're stuck with it, you'll have to accept that and take whatever measures that make it work without sacrificing safety.
surferdude2 is online now   Reply With Quote
